X5 21" E70 wheels onto a 2013 X6?
rugnugdo
Post by rugnugdo » Fri Jan 29, 2016 3:03 pm
Will a genuine set of staggered BMW X5 E70 wheels fit onto a 2013 xDrive3.0 BMW X6
Genuine BMW X5 E70 21'' 36110416301
325/30 R21 108Y
285/35 R21 105Y
Am i right in thinking i maybe just need a spigot for the rears as the bore is only thing different?
sid10
Re: X5 21" E70 wheels onto a 2013 X6?
Post by sid10 » Fri Jan 29, 2016 3:41 pm
hi just looked on alloywheeldirect.net they seem to be the same offset 10 x 21 et40 front , 11.5 x 21 et38 . Yes spigot rings but I think that it is the front that needs them . just check that they have BMW stamped in side plus the part number if not from dealer ! You will need to have rear arch extention if not a Msport .
  tyres are £1500 plus .
rugnugdo
Post by rugnugdo » Fri Jan 29, 2016 3:49 pm
I make it the X5 wheels are
Front - 10x21 ET40 Bore 74.1mm - tyres  325/30 R21
Back - 11.5x21 ET38 Bore 74.1mm - tyres 285/35 R21
The X6 Requires:
Back - 11.5x21 ET37 Bore 72.6mm
So a spigot to reduce the bore for the rears?
There from a dealer - 36110416301 - came off a 3.0d X5
Post by X5Sport » Fri Jan 29, 2016 3:52 pm
Never seen arch extensions on an E71, regardless of wheel sizes.  Didn't even know BMW offered such.
sid10
Post by sid10 » Fri Jan 29, 2016 5:22 pm
One axle will need spigot rings !
  cant upload the link but check this out bmw x6 wide arch at www.sdprestige.co.uk x6 e71 adair wide arch kit. looks the dogs !
Post by X5Sport » Fri Jan 29, 2016 8:47 pm
Except you don't actually need it for OEM 21" wheels.
rugnugdo
Post by rugnugdo » Fri Jan 29, 2016 9:29 pm
so they will just fit with the spigot on the rear that take the bore down to fit same as x5
