Front brake disc retaining screw
Pradaman
Post by Pradaman » Tue Jan 16, 2018 5:31 pm
Changing the discs and pads on my2009 E70 3.5 D today and the threads on the retaining screw are not the beat. Does anyone know what the thread size is on the screw as I need to tap it out and also do the new discs come with new screws? It’s the screw that holds the disc onto the hub. It is removed using a 6mm Allen key.
snrbrtsn
Re: Front brake disc retaining screw
Post by snrbrtsn » Tue Jan 16, 2018 5:47 pm
I’m sure the thread is M6, the thread pitch I’d be guessing without looking though.
I have a tap in the garage I can check if required
Pradaman
Post by Pradaman » Tue Jan 16, 2018 5:51 pm
That would be great if you could check. I’m not sure if it’s m8 or m6. Need to get a tap in the morning.
gmc15
Post by gmc15 » Tue Jan 16, 2018 6:10 pm
New discs don't come with new screws, you have to buy them separately. I had to drill both of mine out as the garage who changed the discs last tightened the screws too much! Not sure what size tap you need. Don't really know why the screw is there as the 5 wheel studs hold the disc in place anyway!
x6 M50d
Nictrix
Post by Nictrix » Tue Jan 16, 2018 6:40 pm
My new discs that I fitted a few months ago came with new screws.
And the discs for our Z4 came with new screws too.
Maybe different brands of discs give you screws, mine were Brembo.
Pradaman
Post by Pradaman » Tue Jan 16, 2018 6:54 pm
It’s ATE discs I have ordered.
snrbrtsn
Post by snrbrtsn » Tue Jan 16, 2018 7:15 pm
I’m talking drivel (sorries)
Ventured to garage found the tap set and it’s m8 x 1.25
Checked on realoem to ensure I wasn’t mistaken and true enough there M8 x 14mm
Whilst correct, there not really needed, but do make wheel removal & refitment a lot easier unless you have one of these
Though still a pain
gmc15
Post by gmc15 » Tue Jan 16, 2018 7:45 pm
[quote="Nictrix"]
Mine were Pagid and I had to buy new rertaining screws.
x6 M50d
Pradaman
Post by Pradaman » Tue Jan 16, 2018 8:32 pm
Thanks to all who helped here. Had a look in my garage and found the correct tap thanks again.
