Hello,
I have this message and see that the left rear tyre/corner of the car is low. I also hear leaking air when the compressor attempts to inflate.... Is this a serious problem....any ideas?
Also, I am away in the bush far from home, is it safe to drive home before repair.....approximately 7 hours travel??
Please assist
Many Thanks
Level Control System Failure
Re: Level Control System Failure
Most likely a failed airbag which needs replacement. You will have no suspension on that corner so less than ideal for driving.
Thanks for the feedback....much appreciated
