How much should I pay for an Oil Change?
carlos50
Re: How much should I pay for an Oil Change?
Post by carlos50 » Mon Apr 30, 2012 1:41 pm
When i had my Range Rover the guys at Opie recommended oils which are Ester based, Motul, Silkolene etc these being better than Castrol, Shell Helix and so on, i opted for Motul in the RR and was very happy with it, would BMW have an issued with a "better oil"?
Post by X5Sport » Mon Apr 30, 2012 2:17 pm
Depends upon whether it meets the required minimum spec I would guess. If it does then they can't really argue with it.. :)
carlos50
Post by carlos50 » Sat Jul 07, 2012 1:11 pm
Just to resurrect this topic, i am going to go down the route of taking my own oil with me but have found that the Shell site says 5w-30, Mobil says 0w-30 and Castrol says either Edge 0w-30 or Magnatec 5w-30.
I assume Castrol Edge is the better of the two on the Castrol range so i now wonder if 0w-30 is the best bet?
That said, i was thinking of buying Shell Helix Ultra Extra in 5w-30 even though BMW recommend Castrol  :))
Post by X5Sport » Sat Jul 07, 2012 3:39 pm
Edge is the better of the two (IMHO).  Surprised at the 0W30 though.  Perhaps they changed it at the 40d introduction to 5W 30 as mine now is.
The key bits are to make sure you meet BMW LL04 and ACEA B3 & C3 with whichever you choose to buy in the end.  Someone in the Nembership is an oil tech and flagged those two in earlier oil threads.  Don't forget to check this site for a current Eurocaparts discount code on the oil too.... :ok:
carlos50
Post by carlos50 » Mon Jul 09, 2012 9:37 pm
One of my local dealers said 0w-30 grade when I asked them to quote today, seems like there's more choice on flee bay in 5w-30 though.
They quoted £98 to change the oil which isn't bad since they say its 1.5 hours labour and I supply the oil and filter.
Still confused about the grade
Post by X5Sport » Mon Jul 09, 2012 9:47 pm
I think some dealers buy in just one grade of oil for all cars.  £98 sounds like about what I paid (minus a filter) considering they did a safety inspection at the same time.  I had mine changed at 1,200 miles to clear the swarf (if there was any) from the newly run in engine.  Not really necessary, but old school 'good engineering practice' in my view.
