Will a genuine set of staggered BMW X5 E70 wheels fit onto a 2013 xDrive3.0 BMW X6
Genuine BMW X5 E70 21'' 36110416301
325/30 R21 108Y
285/35 R21 105Y
Am i right in thinking i maybe just need a spigot for the rears as the bore is only thing different?
X5 21" E70 wheels onto a 2013 X6?
Re: X5 21" E70 wheels onto a 2013 X6?
hi just looked on alloywheeldirect.net they seem to be the same offset 10 x 21 et40 front , 11.5 x 21 et38 . Yes spigot rings but I think that it is the front that needs them . just check that they have BMW stamped in side plus the part number if not from dealer ! You will need to have rear arch extention if not a Msport .
tyres are £1500 plus .
I make it the X5 wheels are
Front - 10x21 ET40 Bore 74.1mm - tyres 325/30 R21
Back - 11.5x21 ET38 Bore 74.1mm - tyres 285/35 R21
The X6 Requires:
Back - 11.5x21 ET37 Bore 72.6mm
So a spigot to reduce the bore for the rears?
There from a dealer - 36110416301 - came off a 3.0d X5
The X6 Requires:
Never seen arch extensions on an E71, regardless of wheel sizes. Didn't even know BMW offered such.
One axle will need spigot rings !
cant upload the link but check this out bmw x6 wide arch at www.sdprestige.co.uk x6 e71 adair wide arch kit. looks the dogs !
Except you don't actually need it for OEM 21" wheels.
so they will just fit with the spigot on the rear that take the bore down to fit same as x5
