Page 1 of 2
E70 3.0D rear tailpipes
Posted: Tue Apr 12, 2016 6:28 pm
by bn16mostin
Hi all i have a 3.0D 2008 with standard round exhaust tailpipes and would like to fit the bigger m oval pipes, Does anyone know where i can buy these with pipe already on them so i can just clamp them on. Cheers in advance.
Re: E70 3.0D rear tailpipes
Posted: Wed Apr 13, 2016 12:09 pm
by boy2k
Posted: Wed Apr 13, 2016 4:58 pm
The official version needed welding until 2010 and also requires bumper cuts, paint. Later versions are 'cut and clamp' replacements but still needed bumper cuts and paint.
Posted: Sat Apr 16, 2016 9:08 am
by bn16mostin
Brilliant many thanks.
Posted: Sun Apr 17, 2016 10:40 pm
by Wipeout
The OEM clamp on kit is as per the attached, I fitted this last year, easy to do, you need to cut the existing tip as per the instructions, pop out the bumper insert that's there for the standard tip and clamp the oval ones on.
Posted: Mon Apr 18, 2016 10:23 am
by Wipeout
I've got the BMW fitting PDF instructions if you wanted to take a look.
Posted: Thu Apr 28, 2016 10:10 pm
by bn16mostin
Hi yes please i would love instructions and also where did you buy the tips from..email if needed is
[email protected] many thanks.
Posted: Fri Apr 29, 2016 3:31 pm
by Wipeout
E-mail sent bud.
Posted: Mon May 09, 2016 12:20 am
by Sidneyjames
How did u get on with this?
Thinking of doing the same...was it easy enough to do?
Posted: Thu May 19, 2016 9:29 pm
by Wipeout
It's easy to do, I used a mates exhaust cutter, basically a big pipe cutter, cut the existing pipe tips off as per the instructions, pop out the bumper insert to enlarge the hole and clamp on the new oval tips.
Posted: Wed Oct 04, 2017 8:27 pm
by Sit
Any pictures of the before and after of this from anyone?? I do like the square shaped tail pipes but also accept it's quite an expense just for different tips!!
Like to see the comparison of before and after on same car though.
Si
Posted: Wed Oct 04, 2017 9:18 pm
by Wipeout
This any good?
Posted: Wed Oct 04, 2017 9:54 pm
by Sit
I think something went awry......... ::)
Posted: Wed Oct 04, 2017 9:57 pm
by Wipeout
Posted: Wed Oct 04, 2017 10:08 pm
by Sit
Thats better - they look really good a vast improvement I would say. Did you do them yourself? Was that the OEM kit you purchased?
Cheers for the pic
Si
