gearbox problem
Jayx5
gearbox problem
Post by Jayx5 » Mon Oct 29, 2018 6:39 pm
on our way back with the caravan I had it in sport going up a slip road and it jumped out of gear and 'transmission failure' come up on the screen and lost all gears! I pulled over switched it off and re started it and it went back in gear ok so I drove it home and rang bmw assist who were excellent and have just picked up the car and taken it to Cooper bmw in chelmsford.
my bmw warranty runs out on November 15th so if it's serious I could be really lucky.
has anyone else had this problem?
2010 space grey se dynamic pack and lots of toys
Re: gearbox problem
Post by marti » Tue Oct 30, 2018 6:57 am
Keep us up to date, be good to know what caused that to happen....
Jayx5
Re: gearbox problem
Post by Jayx5 » Tue Oct 30, 2018 7:08 am
hopefully find out today
Jayx5
Re: gearbox problem
Post by Jayx5 » Wed Oct 31, 2018 2:15 pm
bmw have just rung me and said it's got no gearbox codes stored but did have a code for a faulty glowplug on cylinder 2, so they have changed that and I've got to pay £165 for them to check the gearbox fluid level as fluids arnt covered under warranty!
I've just spoken to my mechanic mate who said the glow plug problem can do weird things so that might be to blame, is this true?
Re: gearbox problem
Post by Alan Gunn » Wed Oct 31, 2018 5:26 pm
Wouldn't think a faulty glow-plug would affect the gearbox.
Jayx5
Re: gearbox problem
Post by Jayx5 » Thu Nov 01, 2018 1:18 pm
my gearbox needed a litre to top it up so hopefully that might have fixed it, hopefully no lasting damage.
Re: gearbox problem
Post by marti » Thu Nov 01, 2018 6:11 pm
Hope thats sorted it for you....but where did the missing Ltr go ????
AdamsX5
Re: gearbox problem
Post by AdamsX5 » Thu Nov 01, 2018 6:26 pm
[quote="Jayx5"]
Lucky you had a bmw warranty as other warranties try to wriggle out of anything. I would get an end if warranty check pretty soon so any work can be done before it expires.
Jayx5
Re: gearbox problem
Post by Jayx5 » Thu Nov 01, 2018 6:37 pm
they changed the glow plug under warranty but my dodgy steering wheel button and a rear door jammed  door pin isn't covered.
they did do a health check and sent me a video of it which was nice as I now need 2 rear tyres as the inners are down to 1.6mm :(
I'm gonna put my winter set on so that can wait until spring.
AdamsX5
Re: gearbox problem
Post by AdamsX5 » Thu Nov 01, 2018 7:03 pm
[quote="Jayx5"]
Did they change all the glow plugs? I would have insisted as changing one can lead to problems in others. If one is faulty is very likely the rest are on their way out too.
Re: gearbox problem
Post by X5Sport » Thu Nov 01, 2018 7:03 pm
[quote="marti"]
Exactly.....losing 1-Ltr should be obvious from the amount of oil staining underneath.  It doesn’t evaporate.
Jayx5
Re: gearbox problem
Post by Jayx5 » Thu Nov 01, 2018 7:28 pm
they said a litre on the phone but probaly meant they have charged me for a litre.Image
Re: gearbox problem
Post by Leslie » Tue Nov 06, 2018 10:49 pm
The 1.6mm tread depth rule is only for the central 3/4's of the tread so if the centre is ok there is life in the tyres yet ( just saying )  :) Id think the minimum charge was 1 litre of oil even if you need a spoonful ! If there are no leaks then it was probably low when they sold it ..
