Hi all and hope you had a nice Xmas.
Anyway had the car checked as it was pulling to left.
Noticed the tyre pressures were too high in rear so reduced to 2.4kpa on rear. This helped a lot but car still drifted to left. Bear in mind I have an Alloy that’s slightly bent in front left corner but not cracked.
The results showed that the 4 wheel alignment is indeed out and this could be causing pull.
Do I get this sorted and change to winters or do you think when I get winters I will need to do it again?
I’ve attached the results.
Don’t get the camber caster toe thing .
4 wheel alignment check
- 0993750E-B7F6-4357-927D-C8BA84F5E44F.jpeg (305.4 KiB) Viewed 983 times
- 98F95BA2-0202-4948-816D-A41B143A30FF.jpeg (354.54 KiB) Viewed 983 times
- B80E03B6-3B5C-4126-9B1D-60A6DCD95890.jpeg (379.43 KiB) Viewed 983 times
Re: 4 wheel alignment check
The printout shows same. With these results which way would the car pull. Left or right ?
The kwikfit guy said right then changed his mind.
- 6D636AD7-B7ED-4F32-9F84-C9E59DD43692.jpeg (327.94 KiB) Viewed 966 times
