Rear floor board wet
Posted: Tue Jan 22, 2019 6:19 pm
by edawg2512
Hello all, newbie here. I have a 2013 X5 E70, I been having an issue since the temperature has been getting colder. In the mornings, the inside of my windshield and rear hatch has frost on it, not any of the side windows. I did notice my rear floorboards on both sides were damp. I dried them out, and it was dry Friday. After the weekend with dry conditions and maybe a 30-minute drive came out Monday to frosted windshield and rear mat frozen to carpet, due to it being wet again. I also noticed water in the battery well, but dried that up
-vapor barriers in rear doors checked by shop and found no issue
Is there any other known reasons for this issue that anyone has come across?
Re: Rear floor board wet
Posted: Tue Jan 22, 2019 7:04 pm
Did they remove the door cards and check the barriers, or just hope? Look for any signs of water on the bottom of the door cards.
Do you have a sunroof? If so check the drain channels and also that the glass is down and sealed.
Rear Door seals? Rear light clusters - for the battery area leak
Posted: Wed Jan 23, 2019 10:13 am
by edawg2512
Yes, they removed panels and tested. I do have a sunroof, but never use it, and it we have had no precipitation for about a week
Posted: Wed Jan 23, 2019 6:03 pm
I have seen mention of a problem with the rear washer hose coming apart in the rear and it being under the carpets. Are you losing screen fluid from the tank?
Posted: Wed Jan 23, 2019 6:47 pm
by marti
Open the sunroof and see if there's any water in the channels....
Posted: Wed Jan 23, 2019 6:48 pm
by edawg2512
Not at this time, never have had the washer low warning before, and I have topped it off since the amount of salt they use on the roads, but i wouldnt say its more than im using?? I also been reading something about an A/C evaporator being in the center console, a drain for it being clogged, but its too cold to use A/C?
Posted: Wed Jan 23, 2019 6:53 pm
by edawg2512
marti wrote: Wed Jan 23, 2019 6:47 pm
Havent used sunroof yet, but there hasn't been any form of precipitation between the time the carpet was dry vs. it being wet.....(its not soggy wet, but it is damp, but when i push down, water isnt coming up, but it is pretty damp...with no odor
