unkonwn wire
neil50
unkonwn wire
Post by neil50 » Thu May 21, 2020 9:19 am
Calling out to see if anyone knows what the wire is supposed to connect to?
It hangs off one side of the rear heated screen and is the one with the purple connecter.
It seemed to be taped up with "official" tape that holds the other cables in place but I cant see anything for it to connect to and I don't have any error messages.
I'm baffled.
Thanks for any enlightenment.
Current
2011 E70 40d 7 seat - remapped
Merc CLK convertible
Audi A2
Smart Car
Previous BMW
E32 - 735se, 735il
E39 - 530d touring
E61 - 525i touring, 525d touring (remapped)
Re: unkonwn wire
Post by X5Sport » Thu May 21, 2020 9:21 am
As it looks to be just brown it’s a ground wire so should be connected to the chassis. Maybe it’s used for an option you don’t have/need?
neil50
Re: unkonwn wire
Post by neil50 » Thu May 21, 2020 9:47 am
X5Sport wrote: Thu May 21, 2020 9:21 am As it looks to be just brown it’s a ground wire so should be connected to the chassis. Maybe it’s used for an option you don’t have/need?
Thanks for the reply,
I would have thought if it was a standard ground wire for the chassis that it would have a ring on it and not a proper connector.
I thought about options but cant think of anything that would go to the back screen?
Current
Audi A2
Smart Car
Previous BMW
E32 - 735se, 735il
E39 - 530d touring
Re: unkonwn wire
Post by X5Sport » Thu May 21, 2020 11:09 am
BMW also use connector ‘combs’ that use spade connections in order to connect multiple wires to a single point - power or ground. Quite why one is on its own I can’t say unless it’s a test point for dealers - and they don’t normally look like that either. It can’t go very far and I can’t see anything in range so to speak. Could have been for a daughter board or any number of options. If it’s not causing an issue then it isn’t important. Earlier generations had a single loom with everything included even if not used on that specific car.
A few comb examples - https://www.realoem.com/bmw/enUS/showpa ... Id=61_1349
neil50
Re: unkonwn wire
Post by neil50 » Thu May 21, 2020 11:16 am
Its not causing me a problem and I am not getting any error messages.
I am just a very inquisitive person and don't like not knowing what something is for :) :)
Current
Audi A2
Smart Car
Previous BMW
E32 - 735se, 735il
E39 - 530d touring
Re: unkonwn wire
Post by X5Sport » Thu May 21, 2020 11:31 am
A good engineer then ... :D
