New tyres required
Posted: Thu Jul 21, 2022 12:52 pm
by lynx2022
Hi All; picked up a nail unfortunately in a rear tyre. Possible new tyre required. I just want to check, as there seems a lot of debate on-line about tolerances for tyre tread depth differences on X Drive vehicles. Mine is the GO1, 2.0d, almot 2 years old, so I don't want to invalidate any warranty with regards the X-drive/transmission box etc.
I accept that both tyres on the same axle will have to be replaced together: Rear tyres seem to be over inflated, (though they are not, double checked) as tyre wear has been consistently more in the tread centre. Anyway, I have minimum 3.5 mm tread rear, & 4.5mm across both front tyres. Given that new Pirelli PZeros will have 7 mm?? tread, that would give a difference of 3.5 mm between front & (new) rear treads. Is this within BMW tolerances? Can I get the correct information on these tolerance to ensure compliance with BMW recommendation?? Thanks
New tyres required
Posted: Thu Jul 21, 2022 1:10 pm
by StuBeeDoo
I don't know about the G models, but on the earlier cars it used to be max. 2mm tread depth difference between all four tyres. Have you checked in the car's handbook? I'm sure that there's reference to tread depths in my F25's book. Personally, I'd rather go by that source as dealers are notorious for giving conflicting information.
New tyres required
Posted: Thu Jul 21, 2022 2:35 pm
by lynx2022
Thanks for that. Yes I have checked the handbook, predictably it is very vague, being a pretty much generic manual : “ Replacement of wheels and tyres
Fitting and balancing
Have the wheel fitted and balanced by a Service Partner of the manufacturer or another qualified Service Partner or a specialist workshop.
Wheel/tyre combination
General
Information on the correct wheel/tyre combina‐ tion and rim designs for the vehicle can be ob‐ tained from a Service Partner of the manufac‐ turer or another qualified Service Partner or a specialist workshop.”
New tyres required
Posted: Thu Jul 21, 2022 6:10 pm
This is straight from the official manual …… note last paragraphs as well. 2mm difference anywhere.
- E386946B-1E3E-41EA-9F07-80E67EB85455.jpeg (93.84 KiB) Viewed 29320 times
New tyres required
Posted: Fri Jul 22, 2022 7:21 pm
by lynx2022
Interesting……thank you; is this available to download from BMW? I saw the technical manual online, but it required a login to access the information. 2 mm is not much difference, & would indicate that I would need to replace 4 tyres, due to a nail in one of them
New tyres required
Posted: Fri Jul 22, 2022 7:55 pm
Sadly not. It came from a site since ordered closed down by BMW. Today it’s behind a paywall. Annoyingly even their parts system that used to be readily available went on line only for dealers at the end of 2019 so cars made since can’t have parts checks other than through a main dealer.
I had a defective tyre on the X6 a couple of years back and that forced a complete (expensive) full set change. I wasn’t pleased.
New tyres required
Posted: Fri Jul 22, 2022 9:18 pm
by lynx2022
Thanks for your help!
