Hedge-Hog issues - another possible resolution
X5-D-Sport
Post by X5-D-Sport » Sat Nov 25, 2023 11:20 pm
These Hedge-Hog units are a sodding nuisance.
I have a NEW issue resolution to throw into the mix.........
A month ago I was also having fan issues, & swapped out 3 regulator hedgehogs to no avail, & getting intermittent fan operation now & then.
I found the remedy quite by mistake.... when groping the wiring harness while the ignition was on, & the fan controls were powered ON.
It turns out that the connector socket that plugs into the Hedge-Hog has female pins that can expand & cease to make contact with the Hedge-Hog MALE pins, or intermittent/poor contact.
If it is a poor or light contact, then the connector sockets/pins will heat up & fail due to the heat & burned connector, then you fit another Hedge-Hog & a few days later the whole situation repeats again.
The hotter an electrical contact becomes, the more electrical resistance is generated until the contact gets scorched/burned & fails.
I found that the fix was to very slightly bend the male pins of the hedge-hog module to ensure a good connection in the wired plug connector.
This may not be the fix for every issue with this temperamental device, but may be worth considering.
Regards to All
Grant B
Post by X5Sport » Sun Nov 26, 2023 9:26 am
That’s a great tip. :thumbsup: :thumbsup:
I wonder also if the copy parts also have different sized male pins and this causes the female receptacle to be expanded so making the situation worse?
Post by henrym3 » Thu Nov 30, 2023 8:25 pm
It’s an interesting point, they obviously can last a long time as the b3 one was/is stamped 1999 so 24yo but certainly if any of mine play up again I’ll try this remedy before splashing out.
