Squeek on rear
Lincssailer
Squeek on rear
Post by Lincssailer » Tue May 11, 2021 4:42 pm
When i reverse slowly my x5 has started a squeeking from the rear shen i go over a bump, any ideas before i start replacing?
Re: Squeek on rear
Post by X5Sport » Tue May 11, 2021 8:26 pm
It could just be a dragging disc pad. After that you’re into checking every rotating or moving part (shafts, bearings, bushes etc).
Lincssailer
Re: Squeek on rear
Post by Lincssailer » Wed May 26, 2021 11:36 am
Sounds rubbery like a bush but why only in reverse?
Re: Squeek on rear
Post by henrym3 » Sat May 29, 2021 12:02 pm
Had a similar squeek once and it was the top mount on the rear shock. When the rubber cover was removed the bush was clearly split 50% of the way round. Worth looking at.
Lincssailer
Re: Squeek on rear
Post by Lincssailer » Sat May 29, 2021 2:09 pm
Thanks will do
