Webasto blowing cold air
Zakbelle
Post by Zakbelle » Tue Nov 25, 2014 5:37 pm
Hi I knkw there are lots of posts relating to the webasto but I can't see anything relating to why mine would blow cold air.  Does anyone know why this happens? ??? I've attached a picture of he model ImageImage[img]http://Image[/img]
Zakbelle
Re: Webasto blowing cold air
Post by Zakbelle » Tue Nov 25, 2014 5:42 pm
Oh just to add move checked all fuses which are okay. I've also read that the preheat option (which is the one I want to use as it's getting colder). I'm assuming that since I can ser 2 timers that the preheat option is activated. Is this true? ?
Smeeagain
Post by Smeeagain » Tue Nov 25, 2014 5:52 pm
when you set the timers you should get a little red light next to the button that you use to navigate your way through the menu ie the knob on the right of the console
Smee
Zakbelle
Post by Zakbelle » Tue Nov 25, 2014 5:58 pm
See I do get that and the blowers come on with the fan light flashing but it just blows cold air.?
Post by Horizon » Tue Nov 25, 2014 6:07 pm
Mine blew cold, as well as others having the same problem. Some have had problems with the PCB's some have stripped and serviced their units. Others have fitted new glow plugs and have had results.
Their is LOADS of info and posts on here to cover most problems if you do a search, I think a member on here actually has repaired a few for other members
Zakbelle
Post by Zakbelle » Tue Nov 25, 2014 6:48 pm
Cheers horizon
fenj66
Post by fenj66 » Tue Nov 25, 2014 9:23 pm
Does the nav screen say aux heat or aux vent?
Zakbelle
Post by Zakbelle » Tue Nov 25, 2014 10:12 pm
Horizon it says both but I can't select aux vent
