Running boards needing cleaning? Good deal?
Re: Running boards needing cleaning? Good deal?
I'm joking you cheeky bugger! How's the remote? Ordered? Weekend nigh, weather good, no excuse! Apologies
Costco are doing 5L wonderwheels for £7.49
BMW X5 4.6iS V8 SPORT
Oh man - change the avtar!
I'm not paying attention again!
Sanj matey, how's the remap going?
Will probably give Jason a call to book it in for August (Only time I can get time off and that's on a Saturday.
getting back on topic though it is hard to concentrate with that avatar
:hooters:
here are mine before and after using wheel cleaner....
Looking good x555
How long did you leave this stuff on before washing off?
[quote=""X5-MK""]Looking good x555
How long did you leave this stuff on before washing off?[/quote]
Leave it soak in a good few mins then give it a good rubbing in then hose off.IIRC i think i did it a few times to get best results
Gents a tip the wife let me into is Tooth paste is good at getting these things clean apparently its an old housekeeping tip for getting rid of rust.
[quote=""x555""][quote=""X5-MK""]Looking good x555
When I did mine, I used an old piece of scotch brite with the wonder wheels which really helped in removing stubborn marks.
Runabout - E92 3 Series Coupe
Hi just a heads up, I bought the 5l bottle of wonder wheels from costco last week for £6.ish, not sure of the exact price as I threw the receipt away.
I’ve heard just normal bottled water especially evian bottled water really works, it’s to do with the mineral content which molecularly works at an atom level liquidising any stains and pitt marks. Go on try a bottle…
tescos wheel cleaner 2 quid for bottle, did the trick last week!!
quickie... can I apply the cleaner with boards on the car or would you suggest removing the boards as cleaner could damage the paints/plastics etc? any hints?
Just put masking tape along the bottom of the doors to add a bit of protection and if you can, avoid splashing cleaner on the paint. It will depend upon how acidic/alkali the cleaner you use is.
If it's only on for a short time it should not do damage to any waxed paintwork. I put bilberry cleaner on with a softish brush and that seems fine.
