Heated front seat
Cole
Heated front seat
Post by Cole » Sun Aug 16, 2015 9:37 am
Drivers side heated seat not working  :( any help in where to look first
Re: Heated front seat
Post by X5Sport » Sun Aug 16, 2015 11:01 am
Check the fuses in the front fuse box (above glovebox), check the connector under the seat, what is the warning light on the switch doing?
Cole
Post by Cole » Sun Aug 16, 2015 11:08 am
The warning light is not showing anything unlike the other that shows 3 settings
Post by X5Sport » Sun Aug 16, 2015 12:16 pm
Sounds like the power is off for that side then.
AW8
Post by AW8 » Sun Aug 16, 2015 6:35 pm
To ascertain if switch is the issue you could swap the left and right switches then test. If no change then the issue is elsewhere.
I am not an electrics expert but will be bold enough to suggest you cant do much more over the advice given without dedicated kit.
(Poll and associated comments removed)
petert
Post by petert » Sun Aug 16, 2015 9:38 pm
If memory of my previous X5 (E53) serves me correctly the back of the switch module only has one large connector which serves all the switches on the module (PDC, HDC, heated seats etc) so it is very difficulty to 'change switches over' as suggested.  You can check the connector under the seats though: do all the other power functions of the seats work?
Peter T
chrisn7
Post by chrisn7 » Mon Aug 17, 2015 12:49 am
[quote="AW8"]
The seat switches are not switches in the old fashioned sense. All the buttons in the switch centre cover a miniature push-button. There is no mechanical switch as such that you can remove. These push buttons are directly mounted on to a circuit board, as are some tiny lighting LEDs and more LEDs for those buttons that have warning lights
Steamyrotter
Post by Steamyrotter » Mon Aug 17, 2015 1:24 pm
When checking the connector ensure the ignition is OFF.
One plug under there has seat occupancy and seat belt tensioner circuits and will ping up your airbag fault light on the dash which will then need resetting....
Please note...
AW8
Post by AW8 » Tue Aug 18, 2015 12:44 am
Pet hate of mine is folly offering bad advice.....Sorry for my earlier comments due to my misunderstanding re the switch panel and buttons.
Thanks to those who clarified thereafter.
Steamyrotter
Post by Steamyrotter » Tue Aug 18, 2015 10:05 pm
[quote="AW8"]
We'll let you off.....
We know its an age thing..
>:D
Please note...
Post by X5Sport » Tue Aug 18, 2015 10:12 pm
[quote="Steamyrotter"]
[quote="AW8"]
We'll let you off.....ŵ
>:D
Yes great grandpa......
AW8
Post by AW8 » Tue Aug 18, 2015 10:48 pm
;D In my 40's but my mind began deteriorating years ago. ;)
petert
Post by petert » Wed Aug 19, 2015 6:56 pm
I'm looking at my forties in the rear view mirror!
Peter T (I think)
