Thanks to AW8 for the suggestion of wrapping my interior grab handles to improve the appearance.
Much like all E53's of this age, the soft touch rubber doesn't stand up well to bejewelled fingers. The drivers door and passenger door were pretty tatty in look, despite my car being a low mileage example.
The rear doors aren't as bad, but you can still see a few marks on the lower half...
Found some cheap leather look embossed black vinyl on eBay, bought around 1.5m of the stuff for something like £6.
I sent out the wife, who's certainly more arts and crafts orientated than I, with some tracing paper to come up with some sort of template, transferred it to card, so I then had a nice solid template to start drawing round and cutting the vinyl. Getting the template right was not easy, it took several attempts to get something I was happy with, and even an attempt or two test fitting some vinyl before I was completely happy with the shape.
In the end, came up with a template from the drivers side, and happily you can turn it over for the mirror image passenger side.
The vinyl suppliers suggested the use of soapy water on the surface first, before applying the vinyl, that way you can move it around until you are happy before you start applying pressure and some heat. Too much soap and they were flying around all over the place, too little and they were starting to stick quicker than I'd like, so a bit of trial and error, but plenty of vinyl left over should I get it wrong.
Simply used a hairdryer for the heat as I gently massaged out any wrinkles, and I'm delighted with the result...
Unfortunately, the door handles in the back are slightly longer, so I'll work on a different template for them but I'm in no rush, the fronts were the priority.
In an ideal world, the vinyl could be more matt in colour, but its surprising how well it matches in with the leather grain on the door cards. Time will tell how long it will last before it gets tatty, but it's been installed for a few weeks now and looks just as good as the day it was fitted. I have plenty of left over vinyl, and it's a quick job now to replace it in the future, providing I hold on to the template.
Cheap and Cheerful Fix - Vinyl Wrap Grab Handles
2006 E53 X5 3.0i Sport
Re: Cheap and Cheerful Fix - Vinyl Wrap Grab Handles
Look's very good.
Have you got a link to the vinyl.
[quote="RossC"]
Here.
You can use the drop down selection for whatever size you need.
Thanks.
Here.
Thanks.
I carried out a full carbon fibre vinyl wrap to the inside of my X5 just after I purchased it 5-yrs ago.
Not until seeing your post now I never considered wrapping the back part of the grab handle to loose the untidy scratch marks. So whilst looking into the door mechanism on the drivers door I popped the handle off the panel and wrapped it, (once you've got the door panel loose it's only x1 10mm nut and x1 torx screw with 10mm nut to remove handle from the panel), personally wrapping the handle off the panel is a lot easier and tidier, what's more you can wrap over the edges making the finish look clean and less chance of the wrapped edge from lifting.
Great job with the vinyl v tidy job RossC
Any photos of the carbon shy7g
05 , 30d Le Mans Blue Sport
