Headlight washers
Murphybarnes
Headlight washers
Post by Murphybarnes » Sun Dec 02, 2018 6:35 pm
So today I removed the screen wash reservoir to clean the filters and get some power in those dribbling jets. On completion I notice the headlight washers do not work. I don't think they have worked for a while...even on Super Wash.
Pump is running and can feel the water going through the tubes. Any ideas, for access or where I need to be looking?
Thanks.....
Re: Headlight washers
Post by henrym3 » Sun Dec 02, 2018 9:51 pm
I believe you you need the lights switched on for water to spray and it will only spray on 4 or 5 sprays of the windscreen wipers.
wpoll
Post by wpoll » Mon Dec 03, 2018 12:21 am
henrym3 wrote: Sun Dec 02, 2018 9:51 pm I believe you you need the lights switched on for water to spray and it will only spray on 4 or 5 sprays of the windscreen wipers.
Correct - but I think that should read "only every fourth or fifth spray" - they don't work every time you hit the button. :thumbsup:
spartacus
Post by spartacus » Sat Dec 15, 2018 12:56 pm
Just rear demist to sort and this car will be a keeper! :tumbleweed:
