fitting heated steering wheel
How-To articles ONLY go here.
bazzyboy
Post by bazzyboy » Sat Aug 07, 2010 10:10 pm
Tools Required:
Phillips & Flat head screwdriver, Torx T-20, Torx T-27 for glove box, 16mm socket & Torque wrench with 6” extension for the steering wheel
PARTS REQ
HEATED STEERING WHEEL----P/N ----323-067-688-33
STEERING COLUMN SWITCH---P/N-----613-183-790-91
RELAY---P/N----61-368-373-700 ---for behind the glovebox
http://flic.kr/p/8qkjFb
thanks sanj for the help you were right already prewired
you need to fit a relay behind the glovebox about 1/2hrs work as means removing the full glovebox and then the fuse box which sits in there if you check fuse 29 and make sure there is a 10amp fuse there this means the car is pre-wired which saves a lot of time there is a small red 3 pin plug taped onto the loom under the top steering column cover if your car is prewired this connects into ypur new column switch.if the car is not prewired it can still be done but you will have to tap into a switched power supply such as the cigarette lighter and run a separate cable to the connector behind the column switch
BEWARE REMOVAL OF THE AIR BAG MUST BE DONE WITH THE KEY REMOVED FROM THE IGNITION OR YOUR AIRBAG LIGHT WILL COME ON and you will need a code reader to remove the light ,fitting of the column switch is easy just remember to connect your extra red lead ,then off with the old wheel then on with the new remember to mark your wheel so when you fit the new one on its in the correct postion nothing worse than a wheel off centre
i am impressed how hot the wheel gets it only takes a matter of seconds to heat up am well happy :D
hope this helps someone sorry for the lack of pics but any questions just ask and i will talk u through it seats are next all the switchgear is in
http://flic.kr/p/8qhbxD
Black 3.0d sport
Sanj
Re: fitting heated steering wheel
Post by Sanj » Sat Aug 07, 2010 11:29 pm
Good man! You OK if I post some pics up on the back of your post? I have some from a PDF I don't seem to be able to find on xoutpost anymore?
Good though isn't it! :D
bazzyboy
Post by bazzyboy » Sun Aug 08, 2010 12:22 am
yeah no probs m8
Black 3.0d sport
Pewters
Post by Pewters » Sun Aug 08, 2010 1:03 am
I want !!!
Turks
Contact:
Post by Turks » Sun Aug 08, 2010 5:05 am
Fantastic mod and sounds pretty simple to do which is refreshing!!
Now... do they have a heated SMG M3 steering wheel?? :evil:
Turks.
Present:
Past:
kena
Post by kena » Sun Aug 08, 2010 9:15 am
:hijacked: Bazzboy, just been looking at some of the other pictures on your flickr.
That white RS2000 is bloody gorgeous, my all time favourite car. :thumbsup:
bazzyboy
Post by bazzyboy » Sun Aug 08, 2010 6:30 pm
thanks kena
it is a animal wife hates it though lol
Black 3.0d sport
X MAN
Post by X MAN » Tue Aug 10, 2010 1:55 am
Here you go guys.
http://www.bmwmotorsports.org/pdf/e53/H ... trofit.pdf
Got this pdf saved on my memory stick, excellent mod and was the first mod i did to my X5.
bazzyboy, hope you don`t mind me posted this link here, i didn`t want to start a new thread for the same how to
and thought pictures might help someone better understand this mod. You say heated seats are next, is that front or
rears or both ?
05 X5 3.0d
X MAN
Post by X MAN » Tue Aug 10, 2010 2:38 am
Apologies :hijacked: agian, agree with kena that RS 2000 really is the muts nuts, awesome looking car mate.
Did you go to the ford show at silverstone last sunday ? went with a friend who also loves his fords, see some fantastic looking cars
including a 206 mph sapphire cosworth.
05 X5 3.0d
Sanj
Post by Sanj » Tue Aug 10, 2010 9:50 am
[quote=""x man""]Here you go guys.
http://www.bmwmotorsports.org/pdf/e53/H ... trofit.pdf[/quote]
Nice one x man - saves me a whole heap of copying and pasting! I was gonna post pics from the same pdf
bazzyboy
Post by bazzyboy » Tue Aug 10, 2010 8:07 pm
[quote=""x man""]Apologies :hijacked: agian, agree with kena that RS 2000 really is the muts nuts, awesome looking car mate.
including a 206 mph sapphire cosworth.[/quote]
didnt make the ford fair was working but my mates went down (andrew gallacher motor sports)they were on the track with the lime green escort cosworth (same engine as my mkii 640bhp) he said it went well :driving:
i had the mk2 on knockhill last month and it really is a handfull its spinning the rear wheels going into 4th :evil:
ps heated seats are front only but have the electric lumbar support on them :thumbsup:
also side steps and le-mans flare kit to go on am going to be busy the next few weekends ;)
Black 3.0d sport
