2008 E70 3.0 SD centre display lifeless
Callums dad
Post by Callums dad » Tue May 03, 2022 7:30 pm
Hi all, tried a quick search but couldn't pin point anything easily. So today whilst driving along the satnav display, cd player and parking sensors all go off and won't come back on.
I have tried to disconnect the battery, check fault codes (won't communicate with the CCC or cd player) and check fuses (under dash - ok).
Can anyone please suggest where to look now? Car drives fine, and AC control panel working.
Thanks in advance.
Post by Leslie » Tue May 03, 2022 7:53 pm
There are a load of small fuses in the drivers side of the boot behind a trim panel ,there should be a piece of paper in there tucked away will tell you what they are for :D Worth a look :thumbsup:
Post by X5Sport » Tue May 03, 2022 9:37 pm
This might help: https://fusecheck.com/bmw/bmw-x5-e70-20 ... se-diagram
or this one as another version: https://fuse-box.info/bmw/bmw-x5-e70-20 ... -and-relay
As yours is a 2008 you will have the CCC computer based iDrive. Fuse 142 in the rear is for the CCC.
There should be a fuse card tucked away in the rear box as said above.
Callums dad
Post by Callums dad » Tue May 03, 2022 9:56 pm
Thank you for the replies, I have checked the fuses under the dash which were all ok. I will look at the ones in the rear and report back. :thumbsup:
Callums dad
Post by Callums dad » Wed May 04, 2022 7:20 am
I have this morning checked the fuses in the rear of the car and they are intact, I'm wondering if this is starting to point at a failed CCC unit?
I'd be interested to know if anyone has had one of these units repaired successfully. :D
Post by X5Sport » Wed May 04, 2022 5:38 pm
Not had one fixed myself but try someone like Cartronics in Surrey.
Callums dad
Post by Callums dad » Wed May 04, 2022 5:48 pm
Thanks for your reply. It looks like I may of found the cause of the issue but it's not great news!! My little boy (2.5 years old - you know that type). Has been feeding coins into the dvd player when he was left unattended for a few seconds yesterday and it's believed to have shorted the power supply board inside the unit itself
I have managed to find someone who has lots of experience with diagnosis and repair of the CCC module and I have arranged to send it to him once I've removed it for test and hopefully a repair.
I will update when I have more news and supply the contact details to anyone interested. :thumbsup:
Post by Leslie » Wed May 04, 2022 6:46 pm
The rascal :rofl: No pocket money for him for a while :rofl:
Post by X5Sport » Wed May 04, 2022 7:38 pm
Ah yes, I’ve got one of those too. In his case he hid the car keys when we were 100 miles from home (and the spare). Took us nearly 2 hours to find the key down the back of a sofa cushion!
At least he’s put his contribution to the repair inside ready and waiting…. :cry:
Callums dad
Post by Callums dad » Fri May 06, 2022 9:36 am
Only good news on this update, I removed the CCC module using YouTube videos for reference and sure enough the unit rattled like a piggy bank. I managed to find a video showing a guy stripping the CCC unit to replace a faulty DVD so I used this information to strip it and remove the loose change.
I found the 20amp fuse on the back of the CCC unit blown, so when I rebuilt the unit back up and replaced the fuse I put it back in the dash to test and it all works...
Very relieved and happy to get away with a couple of hours of my time and a 50p fuse to fix. But hats off to Andy Navman 07905245385 for his time in the first place, without his knowledge and information I think I'd of sent it off for a costly and in this case needles repair.
Thanks everyone for there replies to my issue, maybe this will help another parent!
Post by Leslie » Fri May 06, 2022 10:36 am
That's a good save fair play :thumbsup:
Callums dad
Post by Callums dad » Fri May 06, 2022 2:59 pm
Post by X5Sport » Fri May 06, 2022 8:54 pm
Phew……no doubt ‘small’ change will now become an extinct species in your car :P
Post by marti » Sat May 07, 2022 5:35 pm
Thats great news and a cheap fix, which is what we like to hear :thumbsup:
Callums dad
Post by Callums dad » Sun May 08, 2022 2:23 am
I have been in touch with Andy Navman to inform him of my repair and his reply was....
Top man
I've done over 1000 ccc's
& never have I seen or had 1 with a blown fuse at back of the quad lock power plug
U must be the luckiest man alive
I don't even think u will find reference to it on forums... it just never blows
It's usually always tracks on main board or processor failure
Etc etc
So lucky
So I consider this to be a really good result, maybe I should use the coins recovered to purchase a lottery ticket? :D
