Finally got around to sorting this one out
The gear knob pastic part that often gets sratched by rings/jewlery etc ....or in my case a plaster for a broken hand
can be removed without the hassle of pulling out the whole gear knob/shifter.
I was weary of taking the whole thing out as i did on my last x5 to change the trim and ended up with a dodgy spinning gear knob
which mrs x555 often reminds me about....and duely reminded me today not to f"@k this one up
So after asking the main man on here via text and getting no responce
(you know who you are and slaps will be dealt out at the next meet
I decided to do it the x555 way and pull it apart
By gently prising out the trigger/pull switch part with the aid of a flat headed screwdriver and moving the gear knob back to drive you can then slide the plastic part upwards after pressing in the two clips from underneath...sorry all forgot to take pics when doing this
but it is pretty straight forward.
Then after some sanding down with glass paper and fine wet and dry to prep for painting. I got out the old rattle cans and spruced her up
piccys....
before...and this did get worse after 3 weeks with that plaster on....
During and after sanding down....
several coats of paint later and some laquer to protect it...
and the finished item installed......a very slight difference in shade but hardly noticeable
