side steps--- removing plates only
hi ,i am looking to refurbish my side steps ,i dont want to remove the steps from the car body ,just the metal plates i have removed the rubber bungs all 57 to a side .so now i just need remove the plates are they just stuck on with sealer or held in place by other forces thanks kev
Hi Kev
I removed the rubber plugs and used fine wire wool to bring them up a treat ready for sealing. Not sure how they are stuck down if bonded at all. What kind of refurbishment did you have in mind?
2004 Sapphire Black 3.0d SE
MODS
MODS
Re: side steps--- removing plates only
[quote=""610kev""]hi ,i am looking to refurbish my side steps ,i dont want to remove the steps from the car body ,just the metal plates i have removed the rubber bungs all 57 to a side .so now i just need remove the plates are they just stuck on with sealer or held in place by other forces thanks kev[/quote]
Sealer! Lol, they are bolted to the body of the car and are triangular, if yo look underneath there is a plastic panel the lenght of the step, remove the plastic clips from this and fold down towards the floor, this will release it from the step and you will see what I mean, next remove the clips one at each end what hold the arch to the step, then open both doors and look above the step there is a black plastic strip which pops off, you can now see all the bolds(about 10) remove them and you can tease them out without removing the arches! If your unsure and can wait till weekend I will post you some pics when I re-asemble mine!
current: 2016 Vw Crafter
2007 318d touring
2008 Transit sport van
1964 vw beach buggy
1988 e30 325i convertible
2007 318d touring
1964 vw beach buggy
hi shadrack .i dont want to remove all the side step just take off the metal plates if that is possible
yeh what im saying is its not just a metal plate, its a triangle section of alloy with the top side(the plate) visible and the rest boxed in by plastic!!
http://www.realoem.com/bmw/showparts.do ... =51&fg=95#
here look at this
here look at this
2007 318d touring
1964 vw beach buggy
2007 318d touring
1964 vw beach buggy
thanks =now i understand
they still though arnt really dificult to get off, 30min tops evan if you havnt done them before!! i will take a few pictures then if you change your mind ill post them for you, or do as itbarbie says! im having mine done black but on my old one i removed the step, removed the rubbers and sprayed them alloy wheel silver, they looked great and never corroded again!
2007 318d touring
1964 vw beach buggy
2007 318d touring
1964 vw beach buggy
