XDRIVE badges
XDRIVE badges
Woke up this morning to find some low life scum had stole the X DRIVE 3.0d badges from my front doors,
Would be interested to hear from anyone whom may have some for sale or whom could point me in the direction of a supplier without going to the stealers whom want circa £45 each !
Have tried ebay but with no joy, have also emailed a few breakers, but as yet no joy either.
Cheers,
CR55
Cheers,
CR55
CR55
XDRIVE badges
That is a PITA!
You may want to consider leaving it debadged- many including myself have either removed them or de-selected at order. IMO the side profile looks quite busy with the badges.
If you did want them try ebay- i have seen the odd one pop up there- or go through Cotswold BMW (they give forum members a discount- let them know when you ring them)
HTHs
HTHs
E70 3.0D SE, Black with Black - Gone but not forgotten! >:D
Re: XDRIVE badges
Yes, perfect to not have them ...
911 50th anniversary -
- Don Coffey
Re: XDRIVE badges
Did these thieving scumbag tossers course any damage? I'm taking mine off but intend to use heat to slowly release the glue.
Don
Don
Re: XDRIVE badges
Others I'm sure can advise better, but isn't the trick to poor boiling water over the badges and use dental floss to separate them? I haven't done it myself - got the dealer to do mine before I picked it up - mainly in case some naive green warrior understood it to be a 4 ltr car and showed his 'respects' in the usual destructive manner.
Spare: VW Golf V5
History: TVR Chimera 5.0
Spare: VW Golf V5
- Don Coffey
Re: XDRIVE badges
[quote="MJim"]
Others I'm sure can advise better, but isn't the trick to poor boiling water over the badges and use dental floss to separate them? I haven't done it myself - got the dealer to do mine before I picked it up - mainly in case some naive green warrior understood it to be a 4 ltr car and showed his 'respects' in the usual destructive manner. offensive
I've not heard of this method before. Normal use a hair dryer (borrowed from pvr) to slowly heat up and release glue. Although a little slow (for the glue to release) it works great with no damage to painted surfaces.
Don
Don
Re: XDRIVE badges
Yes, the hairdryer I carry in my boot works great for that. Does make your fingers hurt like mad due to the heat of the plastic
Re: XDRIVE badges
I took mine off, if you want them, away for a week so won't be able to post them for a bit.
Dental floss is the way to remove them.
Re: XDRIVE badges
[quote="pvr"]
Did it mess up the manicure and nail polish too?......... >:D
So that's what the square exhausts are for......they're hand dryers.
Re: XDRIVE badges
Drove behind a nice X6 on my way back from The Netherlands, lovely square pipes on it. Think they are standard in Europe as every single one I saw had them.
Looks so much more "manly" ... but if you have a pink one, guess you are not looking for that >:D
- Don Coffey
Re: XDRIVE badges
[quote="Jalf"]
Ok never heard of this method. Is it as simple as using a back and forth motion between the badge and car?
Don
Don
Re: XDRIVE badges
You just cut the glue then. You will be left with all the gunk on the car, so the heat treatment is better.
Re: XDRIVE badges
I thought you needed both - was how my dealer told me he de-badged mine for me?
Spare: VW Golf V5
Spare: VW Golf V5
- Don Coffey
Re: XDRIVE badges
[quote="pvr"]
Right makes sense now. Heat and floss.
Don
Don
Re: XDRIVE badges
Can't see how you could get second hand ones to stick properly again.
