ignition feed
jimes256
ignition feed
Post by jimes256 » Sat Dec 01, 2012 12:13 am
anybody know where there is an ign feed in rear by cd changer?
Raj
Re: ignition feed
Post by Raj » Sat Dec 01, 2012 12:22 am
There should be as things like the HK amp, etc are all located there. May be worth testing some of the more obvious wires with a tester as off hand not sure.
jaynana
Re: ignition feed
Post by jaynana » Sat Dec 01, 2012 2:25 pm
check this thread. remote mentioned is what you're lookin for..
jimes256
Re: ignition feed
Post by jimes256 » Sat Dec 01, 2012 8:34 pm
Thanks. Where's the bm54 unit?
Reusch
Contact:
Re: ignition feed
Post by Reusch » Sat Dec 01, 2012 10:23 pm
In the boot you need to remove the spare.
JFT96.YNWA
Current
Jaguar XF
Previous
BMW X5 3.0D
Raj
Re: ignition feed
Post by Raj » Sat Dec 01, 2012 11:26 pm
BM54 is under the spare wheel. You need to remove the black plastic cover that is embossed with BMW. Check if you have the wiring and plug (large 54 pin connector for the HK amp) in the left cubby under the cd changer, etc. If it's there as a lot of things are pre-wired with the X5, then a remote feed will be within that loom. Maybe easier to tap off and get to.
