3.0d Economy Re-map
Re: 3.0d Economy Re-map
I am not a diesel owner - I am Not a mechanic only do he odd bit of diy routine home servicing, ( mainly on the Z3).
If I was buying a 3.0d ( & in abscence of evidence of these things being done), I would cause it to have breather changed ,(there is a newer design on later cars that fits earlier models - dont know the change over date), ensure inlet manifold & MAF cleaned(I would not do MAF myself as easily damaged) , maybe add a tried/tested cleaning additive to the tank & ensure injectors/plugs good as well as oil & oil filter fresh. I would also change air filter & ensure no fault codes present.
Others may disagree but thats what I would look at attending to after 1st taking ownership,(unless very low mileage or evidence of attention to same).
Happy to be corrected..........ideally with reasoned explanation.
i cant find the plugs on mine!:)
Ive had a remap by elite and although the power improvement is great it seems worse at part throttle and the mpg from same route and driving style is down from 29.5 to high 22's! its going back to std and Ill try jasons file. But to be honest it wasnt slow before and I dont want to go much lower than 29 for my normal driving
Thanks all for the comments, Jason, I'll let you know next week after this next journey up and down the country this weekend, hopefully without snow!!
ITB: So far I've kept consum#2 since remap and it's showing 28.8mpg today (was 27.7mpg)
Consum#1 I reset for the journey and got the 31mpg reported the other day. Then I reset it on Monday for the daily commute mpg, which is now averaged out over 4 days and about 60 miles of London driving (built up areas/A312 and M4) showing 20.4mpg, so not 14mpg anymore (previous was 23mpg, but London traffic has been like walking this week due to not getting out of bed early enough
Monday will be the tell tale average, as then I will have about 1200 miles pre-remap and 1200 miles post-remap with the same locations and mix of driving to make comparison.
AW8: points noted thanks, the car is FBMWSH, with an additional (unneeded and ahead of schedule) oil change by the supplying dealer at the end of December. Air filter and airflow meter are valid points.
As for the tank additive, I'm considering this, even though I've had bad experiences in the past (albeit a different animal, my old Nova back in the 90's got the redex treatment from me
bottle in the tank, airbox off and poured in the carb, and some down the plug holes......... the amount of smoke generated when firing it up was unreal! result I thought, nice and clean and carbon free
that was very true, it was now carbon free and the engine then progressively rattled itself to destruction in the matter of 2 weeks.
JV
JV
Current: E53 Facelift 3.0d Sport Exclusive, Sterling Grey/Black Nappa Leather, comms, 20"'s, heated steering wheel :p just remapped by Jason @BW Chiptune.
(Previous X5 4.4i Sport, Black/Black, comms, 20" 168's)
Also: E31 840Ci
Previous: 911, M5, 540, RR, 30ish BMW's
Also: E31 840Ci
- jason@bwchiptune
- Contact:
[quote="B1G JV"]
JV
If your doing 1200 mile runs I can lend you one of your flashers
I will make you a few remap files for you to test like I did for Nigel as he does a lot of miles and towing at the same time
Let me know when you will be down as I will need some time to make the files
Also can you tell me what speed you are driving at on the motorway and what the revs are at
Sanj everyone knows your stats jig spilt the beens
JV
TUNING DEALERS ACROSS THE UK
DYNO DYNAMICS ROLLING ROAD
http://www.bwchiptune.co.uk
02085611818
02085611818
[quote="jason@bwchiptune"]
Will you be at the Wolves meet Jas?
Runabout - E92 3 Series Coupe
Jay, that sounds like a plan, cheers! Anytime that suits you will do for me, well when I'm here
I will be down Monday through Thursday.
It would be good to get a comparison of a few, and review them
(nicely of course)
I drive as fast as the traffic allows Jason, I like to sit between 90 - 100 when cruising.... The X will hit 130 quite easily but not for sustained periods. I will have to check what the revs are doing when I'm at those speeds, from memory not much but I will check.
Cheers, 2 more hours before it's next 300 mile trip.....
Also: E31 840Ci
Also: E31 840Ci
[quote="B1G JV"]
Engine wise & in abscence of other invoices FBMWSH means it has had oil & filter changes. The crank case breather is not a scheduled item and I believe air filters take more messing to change on the diesels. Injectors etc unlikely to have been changed unless they completely fail. Apologies no idea on mileage of your car or whats been done to it in past
I share concerns re additives & thus would only use one if recommended by a technician/mechanic familiar with these engines & of course such products..........if in any doubt I would leave well alone.
update for those interested:
Friday drive home, 300 miles, average speed was about 65mph over the journey (between dead stop and 100):
33.4mpg so, I've managed to get more than 32.8mpg on the return
very slight, but it's better.
Journey down Monday, 300 miles, average speed was 71mph:
31mpg
Overall average since remap is currently 29.1mpg
Stats for Jason if he reads this:
70mph at 2300 rpm
80mph at 2500 rpm
90mph at 3100 rpm
JV
31mpg
70mph at 2300 rpm
80mph at 2500 rpm
90mph at 3100 rpm
JV
Also: E31 840Ci
Also: E31 840Ci
Just wondering why additional 10mph from 70 to 80 adds 200rpm yet the extra 10mph from 80 to 90 adds 600rpm? Does the gearbox drop a gear to reach 90?
do you do much town driving? if so what mpg do you get?
[quote="gchristofi"]
I also thought that was a bit much and need to re-check the figures. (maybe that's 100...... or 70 is 60 etc... bah!! )
Also: E31 840Ci
Also: E31 840Ci
[quote="jimes256"]
Yes, see earlier in post. this week averaging about 21mpg from hotel to work and back, but that's with a fair bit of motorway in between. (London driving with M4 and M25 thrown in) if drove round the doors like I would with my V8 (petrol) I return about 14mpg (compared to 16-18mpg in the V8, however that gets between 16 and 21mpg regardless of how, where and how fast it's driven!)
Also: E31 840Ci
Also: E31 840Ci
B1G JV............thanks for sharing.
Clearly mpg on your mind.
Did you bother with my prior suggestions, (MAF & Inlet Manifold cleaning plus breather & air filter changes) ?
- jason@bwchiptune
- Contact:
[quote="Rusty"]
If it's the 1 on the 27th I will be there
02085611818
02085611818
- jason@bwchiptune
- Contact:
[quote="B1G JV"]
(nicely of course)
Let me know when you can popin so I can set up the tool for testing
From there I can email you tweaked mod files if needed
02085611818
02085611818
