intravee indicator flash help
mikem
Post by mikem » Fri Feb 01, 2013 6:32 pm
Fitted an intravee today and flashed it with the latest software (6941).
I have the indicator flashes working but on changing direction from Left to Right (or vice versa) I only get 1 flash not the selected No of flashes the first time its used ? Does that make sense ??
ie, if I use Left indicator all the time I get 3 flashes each time but if I then switch to Right indicator I only get one flash the first time I try it, 2nd,3rd time etc will give the desired 3 flashes as long as I dont interrupt it with a Left flash.
Anyone else have this problem ??
RichardP
Re: intravee indicator flash help
Post by RichardP » Wed Feb 06, 2013 11:42 am
It's to enable you to cancel the extra flashes, if you indicate in the opposite direction whithin the specified number of flashes then it just cancels the sticky blink feature.  So does flashing the main beam.
