Torque converter Noise at lowish revs
X5MO
Re: Torque converter Noise at lowish revs
Post by X5MO » Sun Sep 07, 2014 6:55 am
I understand what you are saying about the waste of money but the TC refurb company did say the TC was worn but maybe they would . Anyway that I can't change now and at least its done.
I will check the tyre sizes later today and I didn't know about the scorpions being winter tyres.
I think I will change the front tyres first and fit 275s summer tyres.
If I still have the noise issue then I will pull the fuse and see if that works ......will removing the fuse cause any other negative effect to the car in anyway ???
Thank you KK
X5 E53 3.0D ( M57N ) 2006
Post by Greydog » Sun Sep 07, 2014 8:25 am
On my 20 inch wheels Fronts are 275 x 40 x 20 Rears 315 x 35 x 20 ? I have read here about different sizes causing issues with the transfer box.
I also know from experience that Subaru are sensitive to this. Just a thought.
X5MO
Post by X5MO » Sun Sep 07, 2014 8:55 am
[quote="Greydog"]
I've checked the oem sizes that BMW quote for 20" alloys and they are exactly as you have them on yours.
I have 315 x 35 x20 rear but 275 X 45 x 20 on the front which should be 40 and apparently are winter tyres so maybe I should just get the advised tyre size on the front. I feel the 45 on the front will be causing an issue as it seems the noise came around the same time as the front tyre change.
Thanks Greydog
Post by X5Sport » Sun Sep 07, 2014 9:00 am
The wheel & tyre sizes should be staggered but the rolling diameter is the key bit.  That /45 set is definitely wrong and will cause problems.  A new set on one axle and a worn set on the other can upset the system and in rare cases destroy a diff - even more so if the wrong size is fitted. Others on here have reported odd issues with non-OEM tyres (BMW ones have a '*' on the side wall) from their 'approved' brands.
I can't see what pulling the transfer box fuse will do either?  The fuse box is likely to be the one above the glove box roof.  It can't be a good idea unless for a VERY short time.  Disconnecting the xDrive could cause other issues.
Winter tyres are fine up to 20C but then the wear can get excessive.  Some folks run them all year with no issues.
Get the right size fitted and the issue should go away.  The right sizes are on the pressures plate on the drivers door 'B' pillar.  There really is no excuse for anyone to put the wrong size on.
X5MO
Post by X5MO » Sun Sep 07, 2014 10:55 am
I hear what you say Richard and the tyres are the logical first step and hoping that resolves the issue. Unfortunately there aren't any stickers on any of my door jambes or pillars.
I will be a very happy man if the tyres resolve the issue and I will have to put the TC repair down to experience but I'm not upset that I've had it done. Thaknk again to all
Post by X5Sport » Sun Sep 07, 2014 1:05 pm
Interesting.......there should be a black & silver sticker visible with the door open which has all the different tyre sizes, weight loading and pressures.
kkx5
Post by kkx5 » Sun Sep 07, 2014 1:56 pm
Ok. Pulling the fuse will confirm the noise is coming from transfer box and You will have Your answer. You will not do any harm. All power will go to the rear tyres.Pull it out, drive it. Put it back on. Easy way to check. I'm working on transfer boxes, repairing them. I know what i'm talking about....In your case, as i mention in my 1st post, noise is from ATC, probably caused by wrong tyres...
Post by X5Sport » Sun Sep 07, 2014 2:07 pm
Is there any way to force it to the front pair to eliminate a rear diff for example?
kkx5
Post by kkx5 » Sun Sep 07, 2014 2:26 pm
No...
Post by X5Sport » Sun Sep 07, 2014 2:47 pm
Typical....... >:(
kkx5
Post by kkx5 » Sun Sep 07, 2014 3:19 pm
Rears are driven by a shaft directly connected with gearbox...
Post by X5Sport » Sun Sep 07, 2014 4:03 pm
Well via the xDrive unit at least with the rear clutch engaged otherwise you can't shift to all FWD or all RWD which the xDrive unit can do.  So if it can be forced to one by pulling the fuse then can it be forced to the other some way?
X5MO
Post by X5MO » Sun Sep 07, 2014 4:22 pm
When I bought it I gave it in for a valet and they steam clean the door sill etc, I've just remembered they said some stickers were loose and could they dispose of them and polish the car ! Now I know which stickers they meant ..Duh
KK- I will try the fuse thing just got roofers at my house so haven't had chance to do anything up to now
Thanks guys
kkx5
Post by kkx5 » Sun Sep 07, 2014 4:51 pm
No..it does not work like that. Clutch pack is only for the front drive. rears are always driven. it can be 100% to the rear with 0% to the front but it cant be the other way round. rear are always driven. rear is driven by a internal shaft, front by clutch pack+chain. By stoping the rears you stop the whole car.You can shift all to the front only by taking rear shaft off. Can not be done by any fuse.
kkx5
Post by kkx5 » Sun Sep 07, 2014 5:02 pm
