Re: Brake fluid leaking on X5 2004 Diesel
Posted: Sat Jan 31, 2015 8:33 pm
[quote="storminmike"]
[quote="TimX5"]
[quote="graemeX5"]
Hi TimX5
You may want to check these links just in case you have any problems with bleeding it, as the bmw system it a bit clever which may need the pressure system and diagnostics laptop to be able to open the valves.
http://xdrivers.co.uk/forum/index.php/t ... l#msg76439
http://xdrivers.co.uk/forum/index.php/t ... l#msg28604
Graeme
Cheers for that Graham , I fitted my new rear flexible pipes back in July bleed them the old fashioned way lol no problems whatsoever , brakes are fantastic , the only thing I've had to pressure bleed in the past was a clutch on a volvo truck a few years ago.
With all these scares of locking out the back then is there method of avoiding this when you say swap the pipe or maybe swap a caliper?
I short terms....did others let it drain too far or perhaps not create a vacuum by sealing off the reservoir?
What's the trick
I just connected the flexi to the steel pipe then put the brake pipe clamp on before connecting it to the caliper so there was minimal fluid loss and blead in the old fashioned way lol
[quote="TimX5"]
[quote="graemeX5"]
Hi TimX5
Graeme
What's the trick
