The troublesome "self level susp inact" error
Gareth83
Re: The troublesome "self level susp inact" error
Post by Gareth83 » Wed Aug 05, 2015 10:06 pm
The O/S brake light seal was damaged (due to age ) so repaired the seal water tested and no longer allowing water to pass. I also carefully drilled a 6mm hole in the corner of the battery well to allow any water to run away before building up.
Total overkill but I siliconed a plastic plate onto the bottom of the plastic housing that retains the modual so it's self contained in its own little housing. (Did this prior to drilling the hole)
04 X5 3.0d sport
