iPhone 6s
Re: iPhone 6s
Your ulf module may well be faulty mine was faulty when i brought it and mine is a late 2005 another one fitted and it paired first time.
Re: iPhone 6s
[quote="robsey29"]
Ah, I've seen that these can go wrong.
Any recommendation on where to buy a replacement, eBay? And, should I try get the latest generation model? Do you perhaps have a part number that could be useful?
(SOLD) 2006 BMW E53 X5 3.0d MSport 20" OEM Rims
20mm Spacers | LED Interior Lights incl NPlate | HID kits | M-Tech Steering Wheel | LED Angel Eyes | 2016 Maps | Digital TV | Upgraded AMP | Engine Remap | LED Tails | LED Side Repeaters | Subwoofer |
Re: iPhone 6s
Realoem will give you all the module numbers and when they came into service. Use the last 7 of your VIN to get the right 'Region' and build type.
Should help you narrow down the cross checks against flebay.
- Steamyrotter
Re: iPhone 6s
From my research ULF numbers as follows:-
Available part numbers of the Bluetooth ULF from BMW
84 21 6 934 552 end of life 06/03 1st generation
84 21 6 938 610 end of life 10/03 2nd generation
84 21 6 934 961 end of life 03/04 3rd generation
84 21 6 950 089 end of life 06/04 4th generation
84 21 6 945 387 end of life 01/05 5th generation
84 10 6 955 522 end of life 10/05 6th generation
84 10 6 969 268 end of life 04/06 7th generation
84 21 6 958 358 end of life 05/06 8th generation
84 10 6 987 546 end of life 9/06 9th generation
84 10 6 980 130 end of life 11/06 10th generation
84 10 9 133 329 end of life 01/07 11th generation
84 10 9 145 007 end of life 05/07 12th generation
84 10 9 154 358 current production 13th generation
Hope that helps..
If it does then I'll have a Gen13 if you want to send me one!!!
lol
Hope that helps..
lol
Re: iPhone 6s
Ok, so I've made some progress here with the BMWScanner 1.4.
Try as I may, my iPhone 6s would not pair via the standard in-car or via PA-Soft BMWScanner 1.4 OBD port. I had cleared all paired phones, reset/rebooted the ULF, deleted all paired devices from my iPhone as well as reset the Network Settings. As can be seen below, no paired devices and pairing failure status:
So I decided to fiddle with the available modes. I switched from Normal (default) mode to Production mode and attempted to pair the phone. It wouldn't pair with the generic passkey '1234567890' but the fixed passkey '****' as supplied WORKED! I was over the moon!
I did notice that the pairing status didn't reflect properly and when I disconnected everything I noticed that although the phone was paired with address book sync'd, I couldn't make and receive calls nor did the radio (audio) work. I plugged the Scanner back in and set the ULF back to default mode. This sorted it out and my phone (and radio) works perfectly now.
After this process I have now also been able to pair my wife's iPhone 6s via the normal in-car process too. I guess the ULF may have just need a number of reboots (kick up the jack) in order to clear a glitch.
The problem now is, when we are both in or near the car her phone pairs first. I'm just too sh!t scared to clear them and try pair again in reverse order... :-[
Re: iPhone 6s
WARNING! Do yourself a big favour and obscure the VIN, pass key, IMEI and MAC address. You are giving enough info to have your phone system cloned and detail about your VIN too. The rest of your VIN is a default for the car type and so very quickly the full VIN is available!
There are too many miscreants on line looking for exactly what you have put on this thread, and you have even very kindly said what type of phone it matches to as well.
Re: iPhone 6s
Thanks X5Sport, anything else that I should blank out now?
