Page 2 of 2
Re: Both front doors won't open
Posted: Mon May 16, 2016 10:24 pm
by nelo
Cheers steamy got the door open and fitted new lock ordered from Cotswold works fine now one job ticked off list just got a sluggish drivers lock now but will wait a while before I order another lock just got to get the hot starting problem sorted waiting for a mate with snap on tester to check fault codes to see if the injectors need looking at would anyone know how easy they are are to get at ?
Thanks in advance lee
Posted: Wed May 18, 2016 11:37 pm
by Steamyrotter
No probs.
Always a pleasure to help when possible.
Injectors need the top cover removing, then the injector pipes.
unplug the wiring and remove the bleed lines
then remove 2 small nuts (one on each side of the injector)
They should then come out..
You may need to persuade the a bit, but mine came out with a small bump with my palm.
replacement in true Haynes fashion is the reverse of removal!!
you will need to make sure that all the holes are covered to stop crud getting in, and mae sure everything is very clean when putting back together
Whilst you are at that point it would make sense to check the crankcase breather and replace with a vortex one if it isn't already...
do a search on here for them, plenty of threads covering them.
