Paddles to facelift steering wheel
Steamyrotter
Re: Paddles to facelift steering wheel
Post by Steamyrotter » Wed Aug 31, 2016 11:54 am
I did it on mine but with Perspex paddles illuminated by orange LED.
used to use it all the time especially when towing.
Was never happy with auto gear change when towing!!!
X5-D-Sport
Post by X5-D-Sport » Wed Aug 31, 2016 1:55 pm
Hi Raj,
Good to hear from you again.
Re the electrical connections under the stick gaitor..... are there 2 wires or 3 wires for each switch ?
I found a pair Range Rover Switch paddles with the switches in, that will fit under the standard steering wheel & a stand alone slip ring that I can fit in addition to the existing one for the electrical connections - courtesy of Fiat lol.
The donor paddle fitments have a little skirt around each switch unit that will make an easy retro fit to the existing steering wheel & be reliable & look good too...
Raj
Post by Raj » Wed Aug 31, 2016 10:02 pm
I'll try and get a pic from my install to show but there's only just one wire for each shift and a ground if that makes sense. The slip ring has two connections only too so again one for upshift and one for down.
Raj
Post by Raj » Wed Aug 31, 2016 10:20 pm
Actually remembered I had a small harness to save cutting into wires but basically this:
Is the connection with the wires. From memory it was the blue and purple centre 2 wires you need to tap into. Can't remember which way round though.
Hope that helps.
x5e53
Post by x5e53 » Thu Sep 01, 2016 5:18 pm
Raj
Post by Raj » Thu Sep 01, 2016 7:13 pm
Yeah I guess tbh as just needs to supply the signal to the relevant wire under the gaitor to manually shift as if the steptronic gear has been used.
