Fan and airco e53 2004 3.0 D Auto
Smeeagain
Re: Fan and airco e53 2004 3.0 D Auto
Post by Smeeagain » Thu Sep 29, 2016 6:58 pm
[quote="henrym3"]
AC fan (nearest front) is primarily to cool the condenser and should run if AC is on. It should kick in if the engine temperature gets to high and beyond the capability of the viscous fan. Although that would have to be a very hot day in traffic queues or a faulty viscous fan. (in my experience) I think the temperature sensor is in the coolant pump/thermostat housing
Ok, so it would appear that this has been two separate problems as the aux/engine fan now does not come on all the time and only comes n when the a/c button is pushed. the problem was resolved when the coolant level was checked and found to be low so its topped up now and fan doesn't kick in, unless, as I say the a/c button is pushed
However, the a/c is still not cold. It was little low (it was degassed in the last 12 months) so they topped it up but still not cold. apparently may be a pressure sensor switch as the compressor has been checked and found to be ok. So still none the wiser on the a/c at this stage
Smee
Smeeagain
Post by Smeeagain » Sat Nov 26, 2016 2:52 pm
Finally got round to sorting this so thought id post back in case it helps anyone else. It was the air con pressure sensor switch - replaced and regassed and all sorted now.
Smee
the shreksta
Post by the shreksta » Sat Nov 26, 2016 7:06 pm
[quote="Smeeagain"]
Smee
just in time for winter  :)) :)) :))
Smeeagain
Post by Smeeagain » Sat Nov 26, 2016 8:23 pm
[quote="the shreksta"]
[quote="Smeeagain"]
Smee
Absolutely. The aircon must be run in winter to stop the seals drying out which is why I was determined to get it fixed as it hasnt been run in several weeks
Smee
Post by Horizon » Sat Nov 26, 2016 8:54 pm
[quote="Smeeagain"]
Smee
Air on is invaluable in winter as it dries the air and steamed up windscreen.
Post by X5Sport » Sun Nov 27, 2016 6:31 pm
I never turn mine off.
