Head Gasket Failure
the shreksta
Re: Head Gasket Failure
Post by the shreksta » Mon Dec 05, 2016 9:08 pm
indeed - agreed.
I will arrange this before the weekend.
Thank you Shreksta
Keep us informed bro.........fingers crossed for you buddy
Post by X5Sport » Tue Dec 06, 2016 10:22 pm
Could also be a failed pressure cap so system will vent instead of retain.  Should be visible around the cap.
If you can borrow a pressure tester for Collins systems that will find it too.  Sniff test simplest of course  :)
Smeeagain
Post by Smeeagain » Wed Dec 07, 2016 12:46 pm
Im perhaps not adding much other than to reiterate we haven't seen any reported head gasket failures on the forum as far as I can recall.
As for Steel-Seal, Im really rather sceptical of anything that can mend a blown head gasket just by popping it in the coolant. The pressures, heat involved etc would all suggest that it probably isn't possible.
X5-D-Sport
Post by X5-D-Sport » Wed Dec 07, 2016 2:02 pm
Yeah.... gotta admit... watery goo to seal a head gasket does sound suspect...but Ive had friends use tgis stuff in performance engines on track days & it kept a vehicle going for years after treatment...
deepblonde
Post by deepblonde » Thu Jan 12, 2017 10:52 am
Just spotted the cooling dropped by 1 pint since yesterday..
AND
there was some mucky gunk floating in the water...
Any way,
Bearing in mind the engine has 170,000 miles on it...
how long does a Head gasket generally last on a 3.0 D Sport ?
I was going to throw a couple of cans of Steal-Seal into it & hope it seals it ?
Any ideas on this ??
Hey any update on your predicament?
Don't keep us in the dark!!!
X5 3.0d Sport, 2006 LeMans Blue, Six-Speed ZF auto, Panoramic roof, Intravee II, Navigation, etc...
X5-D-Sport
Post by X5-D-Sport » Sat Jan 14, 2017 5:48 pm
Update Guys n Girls...
I think X5 Sport has the answer, that a week rad cap is the most likely...
The car has done some 4,000 miles since topping up & not lost a drop..
The logic says the cap is the likely candidate as the weak point, as she was driven VERY hard the night in question & the heat & pressure forced a venting at the weakest point.
Since then, simply done motorway mileage generally 80mph max at night or less, & not lost a drop since.
I will invest in a new rad cap shortly.... but for now, I'm greatly relieved that the engine is OK.
Many thanks to all for then great input & suggestions.
