Increased Battery Discharge
Waka
Re: Increased Battery Discharge
Post by Waka » Mon Feb 05, 2018 5:42 pm
Thanks guys. Just rang my local dealer (Chandlers)and they have the one you mentioned X5sport in stock for £181.81 +VAT (so £218.17 for most of us!).
I did wonder about connecting a trickle charge to the jump points under the bonnet before disconnecting the old battery. I presume I'd lose all manner of settings if I didn't?
Would the trickle charger be sufficient?
Curr. - Silverstone II F85
Prev. - E70 4.0D M Sport
Post by X5Sport » Mon Feb 05, 2018 5:48 pm
My CTEK has a 10A ‘supply’ mode which I used when changing the E46 battery (same size) and it was fine.  Change the battery with the car asleep and it doesn’t draw much.
Graeme
Post by Graeme » Tue Feb 06, 2018 12:05 am
Perhaps I should have made clearer my understanding that the computerised circuits should be kept alive with a 12v source  whilst the old battery is removed and the new one fitted.  I was told not to simply disconnect the old battery, remove it, then fit a new one. Following X5 Sport's contribution, I hope this clarifies the point?
Graeme
Spandex
Post by Spandex » Tue Feb 06, 2018 12:03 pm
Ahh ok, now I get what you meant.
That being said, changing the battery without a power supply connected isn't a problem either. You do get a load of check control messages come up for various modules, but they clear once you start driving. You don't need to clear them using a diagnostic tool, although you wouldn't be changing the battery if you didn't have such a tool, because you need to code in the new one.
<edit> Oh, and I don't remember losing any settings, other than maybe the date/time.
mac1986
Post by mac1986 » Tue Feb 06, 2018 12:07 pm
i sat in the car for about 15 mins yesterday after turning it off and i noticed that the cd or dvd player was making some noises. do you think this could be causing the battery discharge error?
alan996
Post by alan996 » Tue Feb 06, 2018 12:57 pm
Have you dvd based navigation ?
It does run for a bit after you switch off or unlock the car... It's normal enough.
I had the battery discharge issue but it was because my CCC was faulty (failed eventually)
Sent from my Pixel using Tapatalk
