trifecta lights with no speedo & MPG gauge
Loperamide
Re: trifecta lights with no speedo & MPG gauge
Post by Loperamide » Sat Mar 21, 2020 2:10 pm
i have an update for you all.
I swapped both rear and left sensors around. and the trifecta still comes on saying the rear left sensor???
If i turn the car off for 10-20 mins, and turn it back on, the lights disappear, and then come back on after a while.
Post by henrym3 » Sat Mar 21, 2020 2:40 pm
ABS module, provided your confident that you have checked the r/l wiring as best you can. I’m sure I payed around £150 for repair which I preferred to buying used which might be 10 mile away from same problem.
Loperamide
Post by Loperamide » Sat Mar 21, 2020 2:47 pm
henrym3 wrote: Sat Mar 21, 2020 2:40 pm ABS module, provided your confident that you have checked the r/l wiring as best you can. I’m sure I payed around £150 for repair which I preferred to buying used which might be 10 mile away from same problem.
Can you remember which service you used for the repair?
Post by henrym3 » Sat Mar 21, 2020 3:09 pm
https://www.ecutesting.com/
These are the people I used but there are loads of others. What can I say they done mine a few years ago and it’s still fine. I see they charge £200 now.
