Trolley Jack Adapter Wanted
Sanj
Re: Trolley Jack Adapter Wanted
Post by Sanj » Sun Aug 14, 2011 10:00 pm
Make me one then!!! LOL!!!! :rofl:
Just be super safe!
storminmike
Post by storminmike » Sun Aug 14, 2011 10:06 pm
[quote=""Sanj""]Make me one then!!! LOL!!!! :rofl:
Just be super safe![/quote]
Certainly safe....I forgot about the tilt sensor when I had quick play with my new toy/jack....cue mad scramble for car keys :oops:
I have the dimesions...just need someone to tool it...
storminmike
Post by storminmike » Tue Aug 16, 2011 8:30 pm
I have a possible home made solution in METAL
First off- brass rubbing class 101
Leaning under the car with a bit of paper I rubbed over the plastic socket and determined the socket size to be 24mm*160mm (approx)
Suitable Materials
I need a T piece of course...a block bit to go in the slot and a tube bit to mount to the jack too. The T peice can be made in two
The tube bit to mount in the jack
If you have a trolley jack like mine it has a tubular extension piece to go between the cup and the jack itself
If you follow this link it's the bit stored horizontally on the left hand side
http://www.diy.com/diy/jsp/bq/nav.jsp?a ... egories%3C{9372016}/categories%3C{9372052}/categories%3C{9672013}/specificationsProductType=trolley___car_jacks&ecamp=aff-p9-awin-001
So...I have what is a possible vertical tube....just need a solid block to mount on top to fit in said 24mm*160mm slot in chassis
Cost so far....nowt
the block bit
B and Q 20mm *20mm*1000mm square steel tube (with rounded corners too
EAN 3232630201657
Cost £6.65...enough to make 4 but they don't do shorter bits
Chop a bit off say to 155mm
Fastening the tube bit to the block bit
Drill an 8mm hole in 1 face only of the square tube
Purchase 8mm threaded bar (*1000mm long)
EAN 3232630218457
Cost £2.48
Purchase a couple of 8mm nuts
EAN 5020789852985
10*8mm nuts Cost £2.48
Assemble with nut in squaretube screwing threaded bar through drilled hole
Drop into extension tube
thread sizes quoted guestimate of what needed
and this is where I get stuck....a way of bolting up the other open end
any ideas?
I could of course use anothe piece of that box section as an oversized washer I suppose....bit semi permanent though
pvr
Post by pvr » Tue Aug 16, 2011 9:05 pm
[quote=""Sanj""]Yeah he did and so did the tall guy with the tractor and dodgy accent!?!
But a quick search on bay and you'll have what you need.[/quote]
I am watching you ... :evil:
Why do you need any of that anyway? My flat trolley jack just lifts it up fine straight on the jack points without anything else needed.
storminmike
Post by storminmike » Tue Aug 16, 2011 9:09 pm
[quote=""pvr""][quote=""Sanj""]Yeah he did and so did the tall guy with the tractor and dodgy accent!?!
Why do you need any of that anyway? My flat trolley jack just lifts it up fine straight on the jack points without anything else needed.[/quote]
Because the cup damages the mounting points...my jack is not flat faced...it wont slide off...and i'm a bit anal that way :oops:
pvr
Post by pvr » Tue Aug 16, 2011 9:15 pm
ok, mine is simply a round flat face with rubber on it.
My previous jack was also a cup though that fitted perfectly around it as well.
Being anal is absolutely fine though :D
Post by X5Sport » Tue Aug 16, 2011 9:17 pm
I bought mine from this lot in the US.
http://www.reverselogic.us/ReverseLogic ... /Home.html
I think it was after a tip off from the membership here. Solid block if ali with rubber knobs on the ends to keep it snug in the jacking point and a round base which sits neatly in the cup of the trolley jack. I also have sets of their lug bolt guides for the wheel bolts for the BMW fleet we now have :D
Took about a week or so to get here. Watch the order value though as you can get stung for VAT if your order exceeds the import limit!
storminmike
Post by storminmike » Tue Aug 16, 2011 9:20 pm
[quote=""X5Sport""]I bought mine from this lot in the US.
http://www.reverselogic.us/ReverseLogic ... /Home.html[/quote]
I can see the merits of it as it fits snug but the bottom face is flat I believe....unless it isn't?
damage to x5....none...slip off my jack....could do as mines got a small cup 50mm wide ish (guess)?
thanks for the post though
Post by X5Sport » Tue Aug 16, 2011 9:22 pm
Fits fine inside the cup on both my jacks and there's no way it will slip out, but then both mine are about 90-100mm cups. 50mm? I'm not sure I would want to raise an X with that small a cup fitted!
storminmike
Post by storminmike » Tue Aug 16, 2011 9:24 pm
[quote=""pvr""]ok, mine is simply a round flat face with rubber on it.
Being anal is absolutely fine though :D[/quote]
Do you think that the square tube on its side 155mm atop the tube (50mm dia approx)would be man enough....I think so?
storminmike
Post by storminmike » Tue Aug 16, 2011 9:29 pm
[quote=""X5Sport""]Fits fine inside the cup on both my jacks and there's no way it will slip out, but then both mine are about 90-100mm cups. 50mm? I'm not sure I would want to raise an X with that small a cup fitted![/quote]
It is 50mm....I've just measured it...that's why its not so secure
lifting power yes
secure....hmmm...not very
pvr
Post by pvr » Tue Aug 16, 2011 9:42 pm
Very small yes ...
storminmike
Post by storminmike » Tue Aug 16, 2011 9:46 pm
[quote=""pvr""]Very small yes ...[/quote]
..and the jack cup :rofl:
I'm going to make it this weekend 8-)
a welded/machined solution would be better though for practicality :cry:
storminmike
Post by storminmike » Wed Aug 17, 2011 7:44 pm
Errata
I said the the socket size to be 24mm*160mm (approx)...this was wrong
the socket size to be 24mm*60mm (approx)
