Water Pump, Thermostat, Pusher Fan, Coolant & Regas
Re: Water Pump, Thermostat, Pusher Fan, Coolant & Regas
Post by X5Sport » Wed Aug 17, 2011 5:10 pm
:o
Still, it's a few things less to worry about now but....... :o :o
And the VAT bit is :x :headbang:
Labour rate looks good though - around here it's £120 per hour plus vat at the Dealership. I think the indy we use is around £55+vat.
pvr
Post by pvr » Wed Aug 17, 2011 5:20 pm
Similar to my 740, best car I ever had for comfort ...
Sanj
Post by Sanj » Wed Aug 17, 2011 5:35 pm
I know they're never cheap to run but that hurts... :cry:
Hope the blood car shows some appreciation!
pvr
Post by pvr » Wed Aug 17, 2011 5:43 pm
[quote=""Sanj""]
Hope the blood car shows some appreciation![/quote]
Depreciation only old chap ... :D
Sanj
Post by Sanj » Wed Aug 17, 2011 5:50 pm
You're on a role here!
AW8
Post by AW8 » Wed Aug 17, 2011 6:39 pm
Just went to shops , opened boot & found four 1.5 litre water bottles on their side which I prior placed in bungee secured box as water reserve in case coolant ran low.
Some minor leakage........Mopped up what I could see asap
..........Rear of car now in bits, compressor, battery PDC, TM, PDC & radio modules all found totally dry but now elevated.
Now trying to work out how to remove battery tray/box though despite removing fastenings it seems stuck. Don't want to damage battery vent pipework the rear connection s of which I cannot see from inside the car.
Any ideas on how to remove this please ?
Failing this any idea what's underneath ( so I can make informed decision re real need to remove same) ?
Not essential as I reckon less than half a pint leaked and parcel floor carpet soaked up most.
Need to reassemble before darkness :roll:
FML !
:headbang: :headbang: :headbang:
Sanj
Post by Sanj » Wed Aug 17, 2011 7:08 pm
FFS will it ever end for you...
Is this a tray UNDER the battery? Or the WHOLE cradle??? Tbh, I'd probably not know. :thumbsdown:
If the modules all look dry then that should be good. If you can leave them for a few hours/overnight to appease you're worries, that would be good...
Post by X5Sport » Wed Aug 17, 2011 7:14 pm
Take a hairdryer to it, or an electric paint-stripper. If the latter, keep it a reasonable distance away so you don't burn anything. As long as you get things warm and there's a forced air draft it will dry out. We used this trick on Police cars that leaked, or get their boots left open at incidents and our electronics got wet! Never give a copper anything - they'll only break it!! :headbang:
AW8
Post by AW8 » Wed Aug 17, 2011 7:16 pm
I meant whole cradle.
Have now looked underside car & realised how to do this - there are multiple corroded fastenings so will leave same in place.
Like plenty of other car enthusiasts, changing corroded easy to access & change underside fastenings is a job I have not got around to doing.
Have fan heater on removed shelf.
Now going to put another fan heater in back of car -remembering no to leave tailgate lights on so as to prevent battery drain.
Thanks for prompt reply.........If nothing else than to offer sympathy ;)
Sanj
Post by Sanj » Wed Aug 17, 2011 7:20 pm
Burn it!
AW8
Post by AW8 » Wed Aug 17, 2011 7:34 pm
It's not a "car thing" it's more of a "my life at the moment thing" :roll:
Okay I believe I am getting somewhere.
Pretty sure no more electrics are vulnerable. Will leave hot air to circulate a while then reassemble & once floor shelf dried.
Will just need to keep eye on this after a drive in wet to ensure I haven't forced water ingress points by disrupting seal between box/cradle & steel boot floorpan.
Should keep me busy for most early part of evening........ :)
AW8
Post by AW8 » Wed Aug 17, 2011 9:01 pm
Right all done apart from still waiting for carpeted load floor to dry out in front of heater. Boot area all dry, reassembled & spare back in.
Beer open..... :)
