Page 2 of 2
Re: 2002 x5 e53 DSC light and failsafe mode
Posted: Fri Aug 26, 2011 8:52 pm
by strummer
right ok,thanks for that,with it being intermittent I may try swapping the rears over and wait for the fault to reappear,if the speedo plays up it will indicate the passenger side rear being faulty.I will have a look tomorrow if this rain goes off...thanks for the help mate
Posted: Sat Aug 27, 2011 11:21 pm
by strummer
anyone know where the DSC control unit is located? would like to check electrical connector
thanks
Posted: Sun Aug 28, 2011 11:14 pm
by strummer
swapped the rear sensors today,gave them a good clean,just need to see if the fault occurs again and if it does is the speedo effected,if it is its the passenger side faulty,if it isnt both rears should be ok,will then check out the front
Posted: Mon Aug 29, 2011 8:44 am
by x555
If you know anyone or have acces to a code reader it will tell you which sensor is at fault(if it is a sensor)The fronts are the same...not sure on the backs though because of the spedo.
Good luck
Posted: Mon Aug 29, 2011 11:06 am
by strummer
the backs are both the same,I am going to read the codes this week,the lights came on this morning but didnt see the "dsc inactive" message so seemed to be slightly different,will see what happens over the next couple of days
cheers
Posted: Wed Aug 31, 2011 7:48 pm
by strummer
right,the lights have come on again a couple of times,obtained a bmw specific reader that can talk to the bmw modules ie abs airbags etc which gave me a "steering angle identification" fault and there was also a fault with the "rear right side ride height"I did notice a micro switch on either side of the rear suspension when I was cleaning the abs sensors,I take it these are the ride height switches?I have read that the steering angle sensor if faulty will give the warning lights I am getting and if it needs replacing its needs programming to the car,is this main dealer only?
Any thoughts or suggestions from members who have experience of this would be appreciated,
thanks
Posted: Thu Sep 01, 2011 7:43 pm
by strummer
had the codes read at indie bm garage,and it is coming up as a throttle body problem,which would explain why the engine light has come on a couple of times,the steering angle and ride height problems have not reappeared,throttle body will be getting replaced next week
Posted: Thu Sep 15, 2011 4:59 pm
by strummer
had the throttle body replaced a week and a half ago,no further problems with this as yet
