I don't know if the fuell pump is working, there is only one small pipe that leads into the chassis and has no little pump as shown in the PDF's.
Has anyone here actually worked on one of these units ? I am definitely feeling around in the dark and could do with some help
The glow plug slots into a socket at the top end of the burner assembley and is held in place by a metal key. To access the burner assembly, disconnect the air and fuel lines then remove the four screws that secure the fan motor housing then slide the housing off over the fuel line spigot - you can now 'wiggle' out the burner assembly c/w glow plug.
The webasto fuel pump is located under the car adjacent to the main fuel pump and fuel filter - in the void in front of the fuel tank - need to remove the rear-most underbody plastic shield to access the void.[/quote]
That's excellent news, I just disconnected the fuel pipe and tried running the unit and got no diesel, so tomorrow I will remove the cover underneath and check the pump first.
Thanks again great advice
