Page 2 of 2
Re: strange one this morn
Posted: Tue Dec 20, 2011 12:33 pm
by CondorX5
That'll teach you not to read while you're eating!!!
Posted: Wed Feb 08, 2012 8:20 am
by bonerp
when this happens do the door handles go a bit floppy? no tension?
Mine did exactly the same as the OP and the locks etc worked fine on the remote - but my daughter also had to climb out the back doors and both fronts wouldnt open from the outside or inside. She got in ok and I also opened mine, but then once I'd shut it and locked the doors on the remote, I then couldnt open either from inside our out!
Posted: Wed Feb 08, 2012 9:01 am
by shadrack
Mine did it again this morn, cudnt open drivers doors from outside or inside, got to woirk and it was fine! Puzzled
Posted: Wed Feb 08, 2012 12:57 pm
by bonerp
feckin doors - work fine now. Just popped home to see as was going to call the warranty people.
Might spray some silicon oil on the latches tonight see of that helps
Posted: Wed Feb 08, 2012 4:20 pm
by jaynana
i've seen detailed explanations about this in xoutpost. basically once the rubber at the end of the cable that drives the door lock deteriorate over time, moisture gets into the cable.
once moisture is inside the cable, if the temperature drops to sub zero levels like we have now, the moisture freezes inside the cable. effectively jamming the cable.
the remedy if i remember well, was to open up the door panel and replace the cable ends, or ensure that water doesn't get in their..
there's another known problem with x5 door handles - that you shouldn't force! the internal alloy metal frame onto which the external door handle is fixed onto, has 2 hinges which are rather flimsy. force them in this kind of weather and u can break the hinge. good news is that thats such a common fault that usually bmw has this part readily available in stock
- SO DON'T FORCE THAT EXTERNAL HANDLE!
if it was toyota they'd have recalled the whole lot and released a redesign on this door handle i think!
