Re: Why oh why will it not start after battery removal??
Posted: Sat Jan 14, 2012 9:48 am
[quote=""n1k85""]Sureley you'd be instantly better off just buying a new battery?
At least then even with a drain, you will probably still have enough juice to start the car and charge it up again? (when you do finally get it started)
I've only had my X a couple of months and it had the original battery fitted. I was having a problem with the fuel gauge giving an incorrect reading, and because of that I ran out of fuel on a few occasions in the first 2 weeks I had it. This wasn't a major problem since I was already armed with a full can of Diesel in the boot each time, but even when I got the can out and filled the tank, the fuel takes a while to get through the fuel injection system and just turning the car over for 20 seconds or so without it firing up would nail my battery and it would just die!
This was really frustrating because what would start off as Running out of Fuel, then evolved into a flat battery each time, and I had to call out my brother with a set of jump leads!
Even on one occasion I had the radio on for about 15 minutes while I was doing something in the car, and even that was enough to drain it! A few days later and my girlfriend sat in the passenger side with the engine off and adjusted the electric seat to see how it worked, and low and behold, I tried to start the car straight after, and just got click,click,click....
I decided that the original 7 year old battery had to go, so I bought a Bosch S5 Silver battery from Halfords, and I've not had a single issue since. It starts first time every time. We had the stereo on for over an hour while we changed the brake pads, and the other day I realised I'd left the interior lights on overnight and it still started on the button immediately. With my old battery it would be time to get the jump leads out!
You might even find that a new battery sorts out your problem! I have read a few times (and it was certainly the case on my E46) that a duff battery can cause all sorts of random electrical gremlins!
If you're still on your original battery I'd certainly get it changed! it was a PITA for me to just get the jump leads out, so I can't imagine how pissed you are if you have to keep taking the battery out to charge it all the time!!
thx for that, that's so much similar to my experence, although the thing is i dont have a fuel gauge issue, so unless i work on teh car for more than 1/2 hr or so either with radio on (fires a amp+sub as well) or keep interior lights on, car starts ok. but i'm sure my batt is in no great shape either
in a queue of things to do on my X, cos it works its sort of down the priority list though..
