Re: Brake Pipes
Posted: Fri Sep 14, 2012 4:26 am
Get the car lifted and have a look for yourself. Surface corrosion is normal and can be cured with wire wool and a bit of time. You can then either spray them to protect them or cover them in Vaseline / Copper Grease. Get it re-MOT'd either at the same place or go somewhere else.
Most of the lines are hidden under the Plastic Panels underneath the car which keeps most of the salt and water away which means they dont get as badly effected.
For the price he has quoted you could go to the dealers and get new ones fitted and still have some money left over. The standard ones will last you far longer than you are going to keep the car so why get Copper?
Turks.
Turks.
