Page 2 of 3
Re: 2001 3.0d gearbox issue help
Posted: Thu Apr 04, 2013 1:07 pm
by Steamyrotter
Did mine myself..
Not for the faint hearted...
Used a company called Robbs Garage (in manchester) for the valve body work who i would thoroughly recommend for that. I think they may refurb boxes also but not sure. Google them.
And a company called AutoTrans in scotland for the oil pump work who i would NOT recommend.. Bad feelings on that score.
Suppliers for parts i used and recommend :- JP Automatics (JPAT) and Automatic Choice.
Posted: Thu Apr 04, 2013 2:05 pm
by Adam1411
Once again thanks for everyone ones replies i have just picked a gearbox up from automatic gearboxes lancashire and hopefully that will be problem solved i will update with how i get on.
Adam
Posted: Thu Apr 04, 2013 3:49 pm
by Y13HYA
[quote="Adam1411"]
Adam
Fantastic
Posted: Thu Apr 04, 2013 8:33 pm
by storminmike
[quote="Adam1411"]
Adam
you mean you just turned and bought a new gearbox
you must be minted, how much was that if I dare ask?
Posted: Fri Apr 05, 2013 9:47 am
by Adam1411
It wasnt a new gearbox it was a re-conditioned one, got a good deal but still £1200 so fingers crossed thats it will be all done and dusted today
Posted: Fri Apr 05, 2013 7:28 pm
by storminmike
[quote="Adam1411"]
Was that a "supplied" and exchanged price? I guess you're the one fitting it....that's got to be heavy
Posted: Fri Apr 05, 2013 7:36 pm
by Horizon
I thought that sounded very reasonable, as the general price for a facelift box is around 2k or even2.5k fitted
Posted: Sat Apr 06, 2013 2:41 pm
by Adam1411
Yes that was a supplied price.
Ive got a mate to fit it as to do the job on the floor would be a nightmare and he has got a pit in his garage so it made more sense.
I have just been to put the car up drove it 300 yards down the road and it drove lovely in 1st 2nd and 3rd but as soon as it tried to get into 4th or 5th it threw itself out of gear and back into what seemed to be 2nd gear! So we switched the ecu off another x5 but that has not solved the problem does anyone have any ideas on what it might be?
Posted: Sat Apr 06, 2013 5:43 pm
by Horizon
Does it use any external speed sensors, some seem to use input and out put speed sensors , but on one diagram it shows the wheel sensors as part of the input, it looks to be some external sensor or wiring problem that is causing more than one gearbox to fault. Maybe a wire shorting to earth somewhere, I tried post a link to the diagram, bit it wouldn't let me.
Maybe it's time to take it into the Auto box specialist, see if they can get to the bottom of this problem?
Posted: Sun Apr 07, 2013 7:18 pm
by Adam1411
Yes i think it is time for it to go to a gearbox specialist and see if they can diagnose the problem fingers crossed it wont be too bad.
Will update with what the problem was and the fix
Adam
Posted: Sun Apr 07, 2013 11:29 pm
by 4687ah
You have had a bit of a bad run there by the sounds of it. Hope a specialist can get you sorted with the minimum of fuss and further outlay.
Please post whats found as i think gearbox issues are top of the list of things we dont want to go wrong, so i know its no consolation, but your woes may just help someone else out in the future.
Good luck and hope you get a break soon.
Posted: Mon Apr 08, 2013 9:07 am
by Adam1411
Yeah i have had some serious bad luck with it just looking forward to it all being sorted and i can start enjoying the car because at the minute its just and endless money pit.
I will post what the problems are and like you said hopefully someone else can benefit from my misfortune.
I will update when i know more
Adam
Posted: Mon Apr 08, 2013 9:23 am
by Y13HYA
hope you get it sorted soon
Posted: Mon Apr 08, 2013 11:12 am
by Adam1411
Yeah me too starting to pull my hair out with a car
Posted: Mon Apr 08, 2013 11:31 am
by Y13HYA
[quote="Adam1411"]
i was the same with my gearbox issues
