I'm back..........
mogsyman
Re: I'm back..........
Post by mogsyman » Thu May 31, 2012 8:04 pm
[quote=""pvr""]You will like it when you plug in your iPhone, that the album artwork will appear on the screen. Nice touch I think.
Ashame that AW8 will never know what we are talking about as he has only just moved on from his Nokia 6310 ... :poke:[/quote]
Does it do that using the bluetooth connect or the cable?
Don't take the piss out of AW8, his phone is an antique and worth a small fortune! :lol:
2019 F90 M5
2019 Porsche Macan
Previous
2016 X3 20D M Sport
2016 X5 M50d
F10 M5
120D M Sport
335i DCT Vert
997 C2S
30D M Sport X5
2.0D M Sport X3
535D M Sport
4.8iS X5
3.0D M Sport X5
320D M Sport Cab
996 C2 Cab
Boxster S
Golf GTi (150 D)
pvr
Post by pvr » Thu May 31, 2012 8:16 pm
Cable only I think. Not sure you can actually play music via BT as I have not bothered trying that. I plug it in anyway to charge the phone whilst in the car via the normal Apple lead in the USB connection.
Still have not spent the time to try the other iPhone apps on the car which allows you to find the car and continue the satnav route via the phone. Must find the time sometime ...
mogsyman
Post by mogsyman » Thu May 31, 2012 8:56 pm
So I don't need to BMW special cable and can use just an iPhone cable?
In my old 535d I had to use the cable witha USB end and a jack plug which I bought from BMW.
2019 F90 M5
2019 Porsche Macan
Previous
2016 X3 20D M Sport
2016 X5 M50d
F10 M5
120D M Sport
335i DCT Vert
997 C2S
30D M Sport X5
2.0D M Sport X3
535D M Sport
4.8iS X5
3.0D M Sport X5
320D M Sport Cab
996 C2 Cab
Boxster S
Golf GTi (150 D)
Post by X5Sport » Thu May 31, 2012 9:20 pm
Music will play via Bluetooth and via the standard Apple white cable. You will only get track info via Bluetooth, no album artwork (that only works via USB)? The BMW 'Y' cable ceased to be needed after October 2010 builds that had the Combox in them - came with Pro Nav if option chosen, otherwise it was the same old TCU until March 2011 when everything with nav + Bluetooth prep got it.
If you have ordered the full media system with BMW Apps and Smartphone integration then it will also play video via the multimedia snap-in adapter - yours for a cool £170 sir! Standard snap-in (£70) will connect the iPhone to the external aerial, charge it and run the phone/music via Bluetooth. iDrive will also play DVDs.. :thumbsup:
Nothing wrong with a 6310i...! Still got two chassis here...and chargers..the E46 has the snap in for it... :D
mogsyman
Post by mogsyman » Thu May 31, 2012 9:23 pm
[quote=""X5Sport""]Music will play via Bluetooth and via the standard Apple white cable. You will only get track info via Bluetooth, no album artwork (that only works via USB)
Nothing wrong with a 6310i...! Still got two chassis here...and chargers..the E46 has the snap in for it... :D[/quote]
Wft are you talking about?
I'm nearly 50 and can't control a cd player let alone a bluetooth iPhone whatsamajig!
2019 F90 M5
2019 Porsche Macan
Previous
2016 X3 20D M Sport
2016 X5 M50d
F10 M5
120D M Sport
335i DCT Vert
997 C2S
30D M Sport X5
2.0D M Sport X3
535D M Sport
4.8iS X5
3.0D M Sport X5
320D M Sport Cab
996 C2 Cab
Boxster S
Golf GTi (150 D)
mogsyman
Post by mogsyman » Thu May 31, 2012 9:25 pm
Haven't got smartphone integration, just media with enhanced bluetooth........arrgggghhh lost interest now :lol:
2019 F90 M5
2019 Porsche Macan
Previous
2016 X3 20D M Sport
2016 X5 M50d
F10 M5
120D M Sport
335i DCT Vert
997 C2S
30D M Sport X5
2.0D M Sport X3
535D M Sport
4.8iS X5
3.0D M Sport X5
320D M Sport Cab
996 C2 Cab
Boxster S
Golf GTi (150 D)
Post by X5Sport » Thu May 31, 2012 9:28 pm
Er......right......well the simpler answer to your question is yes you can play music off an iPhone via Bluetooth, and no you don't need a special 'y' cable... :D You've got the same as me then. Snap-in is much cheaper.... :thumbsup:
Unless of course BMW have changed the names again in which case you've got the lot, but simple answer still applies.
pvr
Post by pvr » Thu May 31, 2012 9:36 pm
Just shove in a normal iPod cable and press play on the screen. Think you can understand that bit. :poke:
Next thing is that you can load CDs and it will copy them to your hard drive so you can use your internal hard drive as well for music storage. Hope I have not overloaded you now :D
You almost 50? Thought you were closer to 75 ... :evil:
mogsyman
I'm back..........
Post by mogsyman » Thu May 31, 2012 9:39 pm
[quote=""X5Sport""]Er......right......well the simpler answer to your question is yes you can play music off an iPhone via Bluetooth, and no you don't need a special 'y' cable... :D You've got the same as me then. Snap-in is much cheaper.... :thumbsup:
Unless of course BMW have changed the names again in which case you've got the lot, but simple answer still applies.[/quote]
Thanks :thumbsup:
Would you suggest buying a cable or does the Bluetooth work without a problem?
997 C2S
L200 workhorse
X3 for the Mrs.
2019 F90 M5
2019 Porsche Macan
Previous
2016 X3 20D M Sport
2016 X5 M50d
F10 M5
120D M Sport
335i DCT Vert
997 C2S
30D M Sport X5
2.0D M Sport X3
535D M Sport
4.8iS X5
3.0D M Sport X5
320D M Sport Cab
996 C2 Cab
Boxster S
Golf GTi (150 D)
pvr
Post by pvr » Thu May 31, 2012 9:40 pm
Buy what cable? Any iPod / iPhone cable will charge and play the iPhone ...
Post by X5Sport » Thu May 31, 2012 9:52 pm
As he says.....and it will charge it too. Bluetooth works most of the time without any problems. Occasionally the phone and car won't talk to each other, but that's easily sorted. Bluetooth even works with the iPhone in the house......for a short distance at least.... :D
mogsyman
Post by mogsyman » Thu May 31, 2012 9:56 pm
When I bought my 535d I had to buy a BMW cable that plugged into the iPod/iPhone but had a USB and a jack at the other end which plugged into the car to transfer music etc. and charge the phone.
That's the cable I'm referring to.
Have times moved on?
2019 F90 M5
2019 Porsche Macan
Previous
2016 X3 20D M Sport
2016 X5 M50d
F10 M5
120D M Sport
335i DCT Vert
997 C2S
30D M Sport X5
2.0D M Sport X3
535D M Sport
4.8iS X5
3.0D M Sport X5
320D M Sport Cab
996 C2 Cab
Boxster S
Golf GTi (150 D)
pvr
Post by pvr » Thu May 31, 2012 10:00 pm
Yes, any normal cable works fine. Was from early '12 manufacturing, the sales guy did not even realise it had been changed until I just put the cable in and it all just worked.
535dboy
Post by 535dboy » Thu May 31, 2012 10:02 pm
[quote=""mogsyman""]When I bought my 535d I had to buy a BMW cable that plugged into the iPod/iPhone but had a USB and a jack at the other end which plugged into the car to transfer music etc. and charge the phone.
Have times moved on?[/quote]
Yes times have moved on, much faster than you by the sounds of things
I could play music via BT in the smart car!
Porsche can apparently too but I've just plugged in the normal apple white lead that they are referring to here
I know the cable you refer to for the 535, I have it in the X5!
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
Chompers
Post by Chompers » Thu May 31, 2012 10:14 pm
Good to see the banter going strong :D
Secret compartment very handy indeed, have one in my Touring and it has gas struts too :P
Looks like mods will have to open up a sub-Porsche section for the 2 tarts above :poke:
@AW8 is it not time the Sussex boys ventured over this way :fuelfire:
Current
09/59 e61 520d MSport Touring Business ED - Platinum Grey / Cream Beige Leather
Previous
06/06 e53 X5 4.4i V8 Sport - Titanium Silver / Black Nappa Leather
