2001 3.0d gearbox issue help
Adam1411
Re: 2001 3.0d gearbox issue help
Post by Adam1411 » Mon Apr 08, 2013 12:52 pm
Its torture but hopefully will all be sorted in the next few days
Steamyrotter
Post by Steamyrotter » Mon Apr 08, 2013 1:26 pm
When you filled it did you cycle through all available gears at regular intervals??
Then rechecked the fluid?
These boxes can hold a bit of air in the system that needs bleeding out, especially in the torque convertor as mentioned earlier.
As said before you need to know fluid pressures with drive current etc to know whats going on..
The box has 2 internal speed sensors (turbine speed from input shaft, and drive speed from output shaft)
It uses these and several inputs from the CAN bus to deduce what gear is needed, what fluid pressure to apply and to monitor and knowq when the clutches are slipping so it can either increase pressure and hold or throw to Trans Fail Safe.
As a try start the car and unplug the gearbox umbilical.
Locks it in 4th/5th and applies full fluid pressure.
If it does exactly the same as before then you can semi reject electronics issues as they are not in use at that point.
follow link below to the manual for these boxes.
http://koti.mbnet.fi/pro-ht/Kuvat/automaattilaatikko/5L40E.pdf
This shows you pretty much everything you want to know... and stuff you don't....
there is a diagram of the signal paths available in there.
Adam1411
Post by Adam1411 » Mon Apr 08, 2013 2:55 pm
Thanks for that steamyrotter i have contacted the guy who supplied the reconditioned box and he is coming to have a look but from what he has said he believes the problem is a speed sensor so fingers crossed it will be done and dusted today
Adam1411
Post by Adam1411 » Thu Apr 11, 2013 10:13 am
Hi just a quick update after nearly 3 weeks of problems the X is finally fixed!
It turned out that the reconditioned gearbox had problems with the electrics in the gearbox so thank god it did not cost me anymore.
I will upload a few pictures of the car in the next few minutes.
Thanks again for all your advice it has been much appreciated
Adam
Y13HYA
Post by Y13HYA » Thu Apr 11, 2013 11:06 am
fantastic that its finally sorted! :)
[align=center]2003 Estoril Blue X5 4.6iS - LPG Converted  www.xenon-upgrades.co.uk[/align]
Post by X5Sport » Thu Apr 11, 2013 12:07 pm
Great News...... :D
My rebuilt box didn't work correctly either and was completely replaced under warranty too - so no cost to me.  Mine was a damaged casing that was just out of tolerance.
Now you can finally get to enjoy it properly.
Adam1411
Post by Adam1411 » Thu Apr 11, 2013 1:40 pm
I was so relieved to find out it was not anything else as someone posted on here it could have been an oil pressure problem which i was dreading as its cost me a small fortune anyway so was glad it was them who had to put it straight.
Im just looking forward to putting it through it paces over the next few weeks
Adam
