The version of NCS Expert I use is V 3.1.0 and the INPA is V 5.0.2.
V46 Sp Daten files were used to code all these options excepy I needed V47.1 for the tailgate module.
This works for my 2013 MY 40D Msport.
Here a list of options that I've coded to my car and confirmed working..................Please note DO IT AT YOUR OWN RISK i SHALL NOT BE LIABLE IF YOU SCREW UP!!!
TAILGATE BY REMOTE AND BY BUTTON (HKL Module)
SCH_FBD
aktiv
SCH_TOEHKI
aktiv
TASTER_FBD
aktiv
Key fob remote mirror close (FRM -> SPIEGEL_KOMFORT_EINKLAPP)
Lock/unlocking chirp
FZD module
QUIT_AKUST_SCHAERF===== for locking beep,
QUIT_AKUST_ENTSCH=======is for unlocking beep.
ACOUSTICAL_LOCK_CONFIRM ------( CIC Module)
This will produce a extra setting in idrive under DOOR section which will require to tick to ACTIVE before the beep for locking/unlocking.
make sure you turn it to aktiv...
V=Digital Speed (you will have to reset the time after)
KOMBI Module
BC_DIGITAL_V
aktiv
Disable windows safety feature FRM (NFRM) TUERAUF_STOP_MAUT (or FH_TUERAUF_STOP_MAUT_3R)
Opening doors will not interrupt window roll up operation. Normally, if you open a door while the window is automatically rolling up, it will stop the operation. This feature disables it.
2. To view QMVH (LATERAL-MOMENT DISTRIBUTION REAR AXLE) in BC Stalk
Kombi Module - BC_QMVH_ENABLE to activ.
Video in motion (For passengers and recreational use)!
Modifying the script in CIC module.
There are more options that I have not included yet as they're not tested working but in due course I shall post up as of when,here are a few;
Alarm volume increase.
Rear camera in motion activation.
Side camera in motion activation.
Hope this helps in any way.
Mpower.
