Front lights
Front lights
I seem to of lost the oval ring type lamps from the front, forgive the technical terms, I have no clue wether I need whole new units or can the lamp be replaced, is it a fancy defuser or an actual circle lamp, led or????? Help
4.4 silver on chrome 22s
Re: Front lights
Just needs a new bulb each side. It is a diffuser system and called an 'Angel Eye' by most of us, or 'Halo' by BMW.
Unusual to lose both though. Have you had a warning on the dash panel about them?
Re: Front lights
Id check the fuse in the first instance if both have gone of simultaneously.
But as a Rich has mentioned they are just illuminated rings from a single bulb each side.
Re: Front lights
Cheers guys, I get a warning about the rear lights, but I think that's because the previous owner had the led units fitted and I don't think they fitted a cap, I don't get any warning lights about the front, it's just the passenger side but know I know what I am looking at I will have dig in and see what I can find.
Re: Front lights
If you have Xenons then there is an angled cap at the top that just twists out.
