E53 bluetooth antenna location
Posted: Sat Nov 01, 2014 10:17 am
by ustevep
Hi all,
trying to sort bluetooth issue, replaced TCU, but cannot locate antenna - vehicle is 2005 X5 E53 with sat nav, anyone know where it is located, i have an ariel amp mounted on top od cd/DVD rack where some picture show bluetooth antenna should be?
thanks
Steve
Re: E53 bluetooth antenna location
Posted: Sat Nov 01, 2014 10:33 am
:hi:
It should be a small black module mounted on top of the near side rear electronics rack.  A couple of plastic nuts should hold it down.
Posted: Sun Nov 02, 2014 4:31 pm
by ustevep
thanks Richard, mine doesn't appear to be mounted there, see below
Steve
Posted: Sun Nov 02, 2014 6:19 pm
by X MAN
[quote="ustevep"]
Hi all,
thanks
Steve
    Lift up rear seat and pull back rear floor carpet, bluetooth antenna mounted to
  the panel behind the carpet.
    What bluetooth issue do you have ?
Posted: Mon Nov 03, 2014 8:20 am
by ustevep
thanks,
will have a look there,
I cant get the vehicle to produce a blue tooth signal, Navcoder can see the TCU and I have removed old paired phones but cannot get a bluetooth signal out of it, I have got hold of another TCU (same serial number as one fitted, Motorola unit 84106964113) but wanted to check bluetooth antenna is connected before fitting new unit to vehicle.
Steve
