Another issue I am starting to tackle is the #"Self Level Suspension Inactive" error.
The car had been completely level at the rear (only has self levelling in the rear) but wasn't able to adjust suspension from the button on the dash.
The first thing I tried this evening was replacing the piston ring within the compressor. The original ring and seal seemed fine but I thought I may as well replace anyway. Put it all back together and tested the compressor with a spare car battery. The compressor seems to be working away but there is absolutely no air/pressure coming out of the air pipes from the pump.
Does this mean the compressor/pump is knackered or perhaps the actual air isn't pumped until connected to the car? I expected to feel some air being pumped out but nothing. Rear is now completely down to the tyres as all air pressure was released when taking the pump out
As always any help is really appreciated.
